Making a patio if no cables
bigarm
Our new toy hauler does not have the cables to convert the ramp to a patio. For those of you that don't have the cables and want to use the ramp as a patio, how do you do it?
15 REPLIES 15
Dirtclods
TexasChaps wrote:
Dirtclods wrote:
TexasChaps wrote:
Dirtclods wrote:
If you ever at a park and theirs a picnic table you can use those as well.
in English please...:h
Find a picnic beach lower your ramp door onto the edge of it.
beach ? I think you meant to say "bench"... LOL
I can be somewhat pedantic at times...:B
Umm I started off with table and ended up at the beach, AKA bench I must of been thinking about surfing! Sometimes I have ostentatiously learned english with three finger typing and no glasses stuff happens!
AAA Motorcycle RV Plus
TexasChaps
Dirtclods
bigarm
Thanks for all the replies and help. I was checking today and it seems to have the attachment points on both the ramp and trailer so I ended up ordering the cables through the dealership. A little spendy this way, but should end up with the exact cables and hardware needed for our trailer.
TexasChaps
nayther
johntank wrote:
bigarm wrote:
Thanks for the ideas. When working on the couches and happi jac bed today, I noticed that the ramp has the places for the cables. I need to figure out how the cables attach to the trailer and maybe I can rig something up like the factory set up.
Ok, if trailer has places for the cables why not go look at a trailer like/similar to yours with the patio option to see what the mounting hardware looks like so you can make your own, or if a dealer can order the cables and hardware for your trailer, your call.
cables are easy to make, buy the cable/hardware at Home Depot.
DIRT BIKES RULE
'12 Duramax CC short bed
2019 Wildcat Maxx 285RKX
Dirtclods
johntank
bigarm
eDUBz
Bottle jacks on wood or on lynx levelers.
LBZ - Stealth TH - RZR 900 4 - Honda 450X - Paddleboarder - Fisherman - Kayaker
boogie_4wheel
+1 in the jack stand idea. That's what we do too.
2005 2500 Cummins/48RE/3.73, QCLB, 4wd, BigHorn, Edge Juice w/ CTS + Turbo Timer,Transgo Shift Kit ISSPro Oil and LP pressure gauges, GDP 20/2 filters, Custom Diesel Steering Box Brace
'10 Forest River Shockwave Toy Hauler 21'
Honda EU3000I Genny
Y-Guy
Moderator
Moderator
Back when we had our Raptor I made my own. I looked over a couple other Toy Haulers and figured it was very doable on my own. Worked fine, second owner continued to use them he told me.
Two Wire Fox Terriers; Sarge & Sully
2007 Winnebago Sightseer 35J
2020 Jeep Gladiator Rubicon
Bumpyroad
jwstrout wrote:
With a previous toy hauler, I used a cheap set of jack stands on the corners. They allowed a little adjustment for different terrains.
I used to set them on pieces of plywood so that they wouldn't sink on soft ground, and I also glued some pieces of carpet to the top of them to prevent scratching.
Jeff
this makes more sense to me than hooking cables to areas not designed for this force.
bumpy
johntank
If I was/wanted to do this, I would be to make my own cables, problem with this is making sure that the hardware and attachment points are strong enough for the job, and to hold the weight that could be on ramp door/patio.
