Nov-18-2021 02:16 AM
Nov-21-2021 06:31 AM
Nov-21-2021 06:28 AM
fj12ryder wrote:
If I ran my old trailer with tires at the max, I would have the capacity for nearly 24,000 lbs. on the triple axle. Having weighed the trailer, I knew I had barely 15,000 lbs. on those six tires. Absolutely no reason to run max pressure, and suffer the resultant rough ride.
Nov-21-2021 05:54 AM
Nov-21-2021 05:38 AM
Nov-21-2021 04:58 AM
Rollochrome wrote:
Lots of good opinions here. I appreciated the feedback on this thread.
Nov-20-2021 08:18 PM
fj12ryder wrote:Not very common from the posts I read. Most trailers have the minimum or a bit less if they can. GVWR stickers frequently recommend sidewall max for trailer tires.
Nov-20-2021 07:41 PM
Nov-20-2021 09:16 AM
Nov-20-2021 08:45 AM
Nov-20-2021 08:05 AM
Nov-20-2021 07:32 AM
Nov-19-2021 01:42 PM
JRscooby wrote:Cummins12V98 wrote:
Over/under MAX has nothing to do with "PROPER" inflation. There is a reason for every tire there is a Load/Inflation chart.
Weigh your axles and add 5psi to what the chart recommends. This is per GY Tech support for when a person wants to use the brain GOD has given you instead of blindly airing to MAX sidewall pressure.
LOL. "Proper inflation"? Weigh axle, check chart. If the tires on the axle are equally loaded, that 5 lbs is over inflation. OTOH, if you have a 30/70 split, you could still have a tire underinflated.
Nov-19-2021 09:22 AM
Rollochrome wrote:
My Carlisle CSL 16's have a cold max pressure of 110.
I installed a TPMS the same day I bought them.
I read up on these tires and there was nothing about a hot max pressure from Carlisle. I contacted Carlisle and they said there was no "hot max" specified.
So on the maiden voyage with them, I watched the temps rise and rise above 110 to just under 120.
The tires on the sunny side were uniformly higher than the ones in the shade side understandably too.
I read elsewhere that a different manufacturer emphatically states on their website regarding trailer tires to NEVER bleed down HOT tires.
So it begs the question, how much hot pressure is too much? The TPMS system instructs to set alert levels that are pretty high.
What do you think is an acceptable pressure level hot relative to the cold max?
Nov-19-2021 09:01 AM
Nov-19-2021 09:00 AM
Rollochrome wrote:way2roll wrote:
Curious why you are setting to max. Your FW should have a recommended psi .
It does. It came with F rated tires that had a max psi of 100
I replaced them with G rated tires that have a max psi of 110 so I went with the tires max psi rather than what the trailer sticker specified based on the factory equipped tires
