Feb-29-2020 06:43 PM
Dec-19-2024 04:05 AM
We have the exact model and year 5th wheel as yours. There have been issues along the way but we have pulled this trailer across the nation into the Rockies 6 times. It has a lot of miles on it. What I'm upset about most is the how the rear wall of the trailer is not fastened very well to the floor. This allows the entire wall to move back and forth an inch or more when it's being towed. The reason we know this is because the aluminum skirt on the bottom side wall is bent or bowed out on each side right where it meets the corner trim where the rear and side meet. After removing this short section of trim between the slide and rear wall I could actually grab hold of the ladder and push/pull really hard and see the rear wall move!! I removed the sofa and saw the method they used to secure the rear wall to the floor. They only used a thin 3/4 inch aluminum angle and where it was screwed into the back wall was just lauan with no metal support behind it. All the screws had came out of the thin wood and were laying everywhere under the sofa. This trailer is well beyond the 3 year structural warranty so I performed my own repair. Heavy 3 inch angle and screws going into the internal aluminum studs behind the lauan. Now I have no movement. Check your trailer for a bow on each side in the back near the rear wall. I've seen a youtube on this and it's common on Reflections and also other brand of trailers.
Mar-01-2020 03:12 AM
Mar-01-2020 02:46 AM
Feb-29-2020 09:00 PM
Feb-29-2020 08:14 PM
Feb-29-2020 07:19 PM
