MORryde
bbaker2001
Looking to upgade suspension
Was at Phoenix show and found Morryde
there is
SRE3000
SRE4000
and on website I see the LRE4000
any recommendations
also on way down to cancer treatment center the rear 5er tire came apart what a mess
purchased the TST507 TPMS setup and will install
they say to replace with wet bolts also
BB from California
2015 Ram 3500
2001 Cardinal
best friend is my wife ๐Ÿ™‚
25 REPLIES 25
bbaker2001
Thanks
had americas tire put on yokohama LT235 85R 16 10 ply rated
BB from California
2015 Ram 3500
2001 Cardinal
bfast54
TXiceman wrote:
bbaker2001,
The TPMS will not stop damage from a cheap tire blow out. A cheap tire will still blow and cause damage before you can get off the road.
Ken
I strongly disagree with your blanket statement :E
I have a tire pressure monitor system ---and a couple years ago I had a sidewall blowout and it alerted me by a rapid drop in pressure ----and I was able to pull to the side of the road before the tire went completly flat and shredded and tore it....:W
I had enough time to pull over-- enough I received no damage !!!!!
If you do not have a tire pressure monitoring system you will not know:S
(I had Goodyear marathons..Not Cheap by any means)
so your BLANKET STATEMENT Is just conjecture on your part.....(Unless of course you personally have a tire pressure monitor ---and system and the tire just blew up --and you did not have time to pull over)... in which case it did alerts you that you had tire problem ....didn't it...?????:h
It saved me Hundreds ,possibly thousands of dollars.
For Those thinking of possibly having them or ride conversion some parts install things like that I believe in March they have a discount on the parts it when you have them installed at the factory but only in MarchI stopped there last year and looked at the system and got the details that's how I know.
2000 Ford SuperDuty F-350 Powerstroke,Dually.C.C.,.The Tow Monster
2005 Open Road 357RLDS
Prodigy Brake Controller:B
Honda EU3000is Generator
Raytek ,,Garmin 7735/GPS
Doran Mfg-RV360-TPMS
B&W/Companion
Rally's attended so far-21
My Blog
Good Sam Member
bbaker2001
Yea they dont make them like they used to.
we love the setup and it is in sunch great shape.
we just replaced all 5 tires with LT
have looked at many at shows, have not seen any we like and would like to trade for.
it is only 30 ft end to end and will get us into most parks. And it seems we are always hearing about so many problems with new units.
One thing we would like to do is change out the old couch with 2 recliners.
do they make good rv recliners, or should we look elsewere
BB from California
2015 Ram 3500
2001 Cardinal
Dennis_M_M
I'm planning on doing the same this summer with a '05 Newmar.
If you like what you have and it's in good shape - go for it!
'99 Volvo VNL610 - 425 HP Volvo; Super 10 Spd
'13 smart CityFlame on Volvo
'05 Newmar Mountain Aire 35 BLKS
Trailer Saver; Bigfoot; Pressure-Pro.
Our Travel Blog - A New Adventure
bbaker2001 wrote:
Thank you
will call monday.
now the question. Ours is a 2001 Cardinal
exactly what we want and in great shape. When does it get to be to old to put money into.
Only you can answer that,,,
There is an old saying, " they don't build them like that anymore"
It is all in how your camper is treating you, and what you want out of it..
You will get to a point that you will be putting good money into bad . . It is at that point that you will realize it.
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
bbaker2001
Thank you
will call monday.
BB from California
2015 Ram 3500
2001 Cardinal
bbaker2001 wrote:
I am only 2 axle now
12,800 gvwr
2 might be a little cheaper
I was at MORryde last June to get the 8K IS installed on my Redwood, the cost was $3700.00.. and WORTH EVERY PENNY !!!
call Gary Wheeler and set up an appointment... The Shop Supervisor, Rob will even let you stay in the rv at night inside their shop. They give you a shop key to keep while there.. It is a FIRST CLASS operation..
Here is mine -
Me-Her-the kids
TXiceman
bbaker2001,
Ken
Amateur Radio Operator.
2023 Cougar 22MLS, toted with a 2022, F150, 3.5L EcoBoost, Crewcab, Max Tow, FORMER Full Time RVer. Travel with a standard schnauzer and a Timneh African Gray parrot
Vette_Racer
Two 7k's IS and 4 new G rated Goodyears for 2700 a couple of years ago.
KE5NCP
2016 Ram CC Dually, 2011 HitchHiker 349 RSB DA, 2018 Wrangler unlimited Rubicon
bbaker2001
12,800 gvwr
BB from California
2015 Ram 3500
2001 Cardinal
bbaker2001
Wow thank you
BB from California
2015 Ram 3500
2001 Cardinal
kennethwooster
More Ride has some of the best products out there. Go for it.
kenneth wooster- retired farmer. Biblical History Teacher in public HS, and substitute teacher.
wife Diana-adult probation officer, now retired.
31KSLS Full Body paint Cameo
Ford F350 2014 DRW 4X4 King Ranch.
20K B&W Puck mount hitch
tinner12002
bbaker2001 wrote:
What kind of price to change over
and where is the facility
They told me $8750 to do the swap for a tri-axle using 8K axles and you get to keep your old axles, wheels and tires I believe are used on new setup unless you want 17.5 tires and wheels, then that's probably more $. They are located in Elkhart Indiana.
2015 Ram 3500/DRW/Aisin/auto/Max tow/4.10s,Cummins, stock Laramie Limited--Silver
Tequila Sunrise 2012 Ultra Classic Limited
2018 Raptor 428SP
tinner12002
ACZL wrote:
The MORryde 3 has 3" of travel, the 4 has 4" of travel. May not come w/ all the wet bolts if at all. Never fail bushings or not, I'd like to have all pivot points greasable.
Dexter makes a cushioned equalizer similar to Mor-ryde but you can get the wet bolts with it as a kit, just put that setup on my toy hauler.
2018 Raptor 428SP
