Pulled a panel to expose the area under the shower with the drainage. Couldn't find any leaks or problems and it wouldn't leak from the bolt like it normal does when I ran the water.
After cutting away the floor it appears that it is leaking from the front of the trailer and traveling back along the support beams. The darkest/softest parts in the photo are where the bolts are and I believe the support beam runs. Also under the sink in the compartment (where the two spray bottles are) there is another soft spot directly in line with the others.
Im going to double check the sink to see if there are any leaks but I believe the problem could have been from my front window. It was broken and replaced years ago. At first it wasn't sealed well and had a tiny leak. I fixed it right away. Im just not sure if its still leaking around the window/sink/front of trailer or if this is old water damage.
My plan:
1. Run the water and check for any links around sink or anywhere else.
2. Remove the toilet and damaged wood. Inspect the area for any more problems.
3. Based on where the support beams are, I plan on cutting out a solid piece of wood, place it over the damaged area (overlapping), trace it, cut the edges and then stick it in like a patch. I may put some type of extra support around the edges of the new piece of wood if needed.
4. Im going to see if I can replace the soft spot under the sink from under the front of the trailer.
5. Last Im going to reseal all the edges around the front window and anywhere else in the front of the trailer where water could be possibly be leaking in.
Im guessing when I remove the toilet its going to smell just wonderful. Can I easily cap it off? Also to prevent debris from going in the tank.
Thank you for your time
2004 WW FB2200
2003 Dodge Ram 3500 4x4 5.9
