Jan-31-2022 04:37 PM
Feb-05-2022 07:32 AM
JIMNLIN wrote:Jimnlin, you state go by rear axle weight rating , that is fine if you choose to do that, but to recommend it to others, can place them in legal limbo!
Baloney ...... There is no legal limbo with (DOT or other legal theories) for exceeding the truck mfg gvwr. Thats just plain rv website scare myth thats been pushed by a few rv owners opinions..... yourself included.
For those that swear by the trucks gvwr or its gvwr based payload sticker.... loading 3500 Rams rear axle to full 7000 lbs will not exceed a 3500 srw Rams 12400 gvwr.
Feb-05-2022 06:19 AM
Feb-05-2022 04:55 AM
Feb-05-2022 02:46 AM
Feb-05-2022 01:14 AM
Feb-04-2022 12:00 PM
JIMNLIN wrote:
Long or short bed 3500 srw have the same 7000 rawr regardless of GVWR or gvwr based payload sticker numbers.
Looking at Ram Body Builder guide base weight specs shows the same cab/drive train/6.7 Cummins/Aisin/etc std bed...rear axle is around 140 lbs lighter than the long bed version = 5th wheel hitch weight that sits on the trucks rear axle, load carrying advantage going to the std 6' 4" bed.
Feb-04-2022 10:41 AM
Feb-04-2022 06:51 AM
Vpolio90 wrote:
I want to stick with a srw. As of right now im leaning towards a grand design reflection or a KZ durango either used or new.
Since my trucks is going to be a short bed what 5 wheel hitch do yall recommend, also slider or non slider?
Feb-04-2022 06:47 AM
Vpolio90 wrote:
Ken, the maximum payload capacity will be from about 3800lbs to 4000lbs. It will most likely be at 3900lbs from the videos I've seen with people with the same trim level. The 5wh GVWRs I've been looking at have been no more than 11500lbs therefore, having a max pin weight of 2300lbs (using the 20% rule). So I would have around 1600lbs not including passengers, extra cargo, 5wh hitch etc.
Yes, I agree we only plan to have 3 to 6 people when using our camper but the capacity of 8 would only be a just in case situation.
Victor
Feb-04-2022 06:06 AM
Feb-04-2022 05:19 AM
Feb-04-2022 04:43 AM
Feb-03-2022 07:53 PM
Vpolio90 wrote:
I have never thought about a TH. What TH 5er would yall recommend.
Feb-03-2022 04:58 AM
ACZL wrote:
What does everyone think about OP taking a look at mid bunk/multi purpose room 5ers? Offers 2 in mid room, 2 on loft and 2 in rear. Although, I'd tend to agree that a toy hauler (TH) would probly be his best best overall.
Feb-03-2022 04:51 AM
