new water pump - now water filling tank??
Brad_NSW
Just put in a shurflow 4800. Now when I took up to city water, my tank fills and overflows and I get no water pressure.
The pump works great, super quiet, and great flow when I'm not on city water. Yes, the valve is turned to normal and not tank fill.
Any ideas?
USN Ret. 03Ram3500, 5.9CTD, 5spd, SRW, ATS filter, S&B Intake, IssPro (Pyro, Boost, Fuel, Trans & R Dif) SMARTY SR, Prodigy Controller, AirDog 100. 09Montana 3665RE 5er, 6 TST Tire monitors. Pakbrake Ex brake & airbags, 12' Baltik inflatable w/3.3HP OBM
10 REPLIES 10
Bmach
If it is a known trouble spot, why not install the chech valve as a safe guard?
laknox
Planning wrote:
laknox wrote:
Brad NSW wrote:
Thanks PLANNING. Parts on order. Looks like an easy fix and bad check valve makes sense.
If you've got a NEW pump that's backflowing, why wouldn't you warrant it for another one, that works correctly, instead of bandaiding the defective one? :h
Lyle
Because the Shurflo check valve is an historical single-point-of-failure, and a dedicated check valve is a more positive remedy not requiring repetitive repair.
No matter. A new, and properly functioning pump is what was paid for and what should be delivered. If it fails later, then install the other valve.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
Planning
Lyle
2016 AF 29-5K; 2016 F350 6.7, 4x4, CCLB DRW
laknox
Lyle
Brad_NSW
Planning
Any ideas?
More than likely the checkvalve in the pump is bad. This is very common and a repetitive issue with Shurflo pumps.
Install this on the discharge hose coming out of the pump:
https://www.amazon.com/gp/product/B000EDUTN6/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
This model is good quality with metal (not plastic) internals.
You might need adapters to place this in line with your hose; the Shurflo pump connections are specific to those fittings so just cutting the hose and "barbing these in is easiest.
adapters like these: https://www.amazon.com/dp/B000BPECSK/?coliid=I1FX1IZI2CSVX1&colid=32BP8LZDSEKI7&psc=0&ref_=lv_ov_lig_dp_it
laknox
12th Man Fan wrote:
If you have all of the fill valves in the correct position then you have a bad check valve in the pump. Some debris may be the cause.
x2 on the check valve on the pump.
Lyle
pasusan
Call Shurflo - we also got a bad pump and they sent me a new one that worked.
Susan & Ben [2004 Roadtrek 170]
href="https://sites.google.com/view/pasusan-trips/home" target="_blank">Trip Pics
12th_Man_Fan
2014 GMC Duramax 4X4 DRW Crew
2015 DRV Tradition
Old-Biscuit
You stated.....
On city water but no pressure inside...fresh water tank overflowing
Check your valving......something is not set up correctly
