โJan-13-2016 07:44 AM
โJan-22-2016 03:27 AM
Bobandshawn wrote:Buy a Travel Trailer, you can tow a lot bigger TT with the same truck then you can a 5er.JIMNLIN wrote:As far as hauling and towing I think you can haul a much larger load than what the factory says you can. Limitation is tires, but legally you could be in a world of hurt. If you cause a death or injury to someone in an accident you could even be criminally liable even if the weight of the rig had nothing to do with the accident. Lawyers are like that ya know!
Respectfully this comes under......Internet myth.
Every LDT truck in commercial service on the road pulling heavy trailers is carrying weight above the tire placard payload rating or a GVWR number payload rating and in that industry your scenario is a non issue so why is it just RV websites where this myth is constantly spread.
I worked in criminal law, now retired. There was a couple times load and capacity came into play in cases I worked on. I do agree it's a hard thing to prosecute criminally, but these civil attorneys can make mince meat of your insurance company come law suit time. Very well may not be that way in other states, but in California you can't throw a rock without hitting a lawyer----and he'll sue you for it.
The CHP, state police, also will get ya on it. In the majority of cases they merely give you a warning. But here is where it's something very obvious like a 1970 Datsun towing a 3 axle gooseneck with 250 bales of hay on it. Back in 1983-1984 I was pulled over by a CHP in my 1974 Dodge 3/4 ton club cab. I was carrying a load of sod and I'm sure it was way more than what the GVW was on the truck. Lucky for me this was in a mountainous area and about the time he was negotiating whether I'd accept a lesser citation or take my changes running across a scale he got called out to an accident or something so I ended up with a warning.
Bottom line is, if you are overloaded (and its apparent) you could get nabbed.
BTW, I ran my pickup across the scales on our ranch when I got home, 11,200lbs. The GVW was something like 8,600 on that old Dodge.
โJan-21-2016 07:57 PM
laknox wrote:Bobandshawn wrote:
I am looking at a trailer with a hitch weight under 2000 lbs and preferable closer to 1850. And a total weight of 10K or so. Both figures are for the light weight.
I have been looking at hitches. I am thinking of the BD3 hitch on the truck and the Reese sidewinder as I have a short bed. Any thoughts?
I'm a B&W "fanboy", according to some, so I'll go ahead and give my recommendation for the Companion, of any flavor.
Lyle
โJan-21-2016 07:11 PM
โJan-21-2016 06:59 PM
โJan-14-2016 06:44 PM
IdaD wrote:
The weight police when it comes to RVs are almost entirely online. Strap a 5er to a Jetta and yeah it could be problematic. Stay short of that and you're probably not going to encounter any issues. You almost certainly (cause nothing is 100%) will not run into any issues at all running a 3/4 ton as long as you stay within your individual and combined axle ratings.
โJan-14-2016 05:48 PM
โJan-14-2016 05:14 PM
โJan-14-2016 04:49 PM
โJan-14-2016 04:35 PM
โJan-14-2016 09:24 AM
Mile High wrote:
Just be conservative in your calculations. I tried to get by with a SRW 1 ton because the numbers worked, but I couldn't haul water and I was within 200 lbs of the tire maximum on the truck. I pretty much decided I had to go to the DRW.
Truck tows great, but I sure hate it. Wish now I would have just gone to a Class A and a toad and not went down this path. The truck is a PIA to use as a vehicle once you are there (I like to get back in the woods), PIA to park, and us just a waste as a daily driver if you work downtown. It sits in the garage and only gets taken out when it's going to tow, so to me it's just a 2 piece motorhome.
In retrospect - I was better off personally with the smaller trailer and my short bed SRW 1-ton daily driver.
โJan-14-2016 07:46 AM
โJan-14-2016 06:34 AM
Bobandshawn wrote:IdaD wrote:
The Hemi and the Cummins can have the same RAWR numbers. The Cummins adds all the weight to the trucks front axle with little to non weight to the trucks rear axle so both will have similar payloads we use out here in the real world.
Those payloads on your trucks tire placard are a GVWR based payload which isn't used for any legal weight issues.
Also the tire sticker numbers are not on all trucks prior to the '05-'06 era...but on all trucks after I believe the '06 era.
Example only; ... the 2500 Ram 6.4 Hemi or 6.7 Cummins truck may have a 6500 RAWR and have a rear axle weight in the 3000 range which leaves around 3500 lb for a payload. RAWR includes tires/wheels/brakes and rear suspension.
Agreed, but living in California with all these lawyers if a problem ever arises with an accident while towing and it's determined the tow rig was over it's factory listed GVW, in this case 10,000 lbs, then you have a liability. The GVW on a 6.4 and a CTD are the same but the CTD weighs about a grand more due to engine weight regardless of the individual axle weights. Hence I can carry two 500 lb women more in my back seat than in a CTD.
โJan-14-2016 06:10 AM
โJan-14-2016 05:41 AM
JIMNLIN wrote:op wrote:
BTW, the Hemi 6.4 will suck down fuel a lot heavier than the CTD engine, but between the 6-7K more $$$ and the cost of diesel and DEF I couldn't see getting one in a 2500. If the CTD rig came with as much or more load capacity I may of looked at them closer. Probably if you towed a huge amount of miles the CTD would be a better choice.
โJan-14-2016 04:53 AM
