Dec-26-2014 10:41 PM
Dec-29-2014 05:58 AM
allen8106 wrote:
As noted in the thread title this isn’t your typical tire thread. I would like input from others on whether or not to replace my tires.
I have a 2010 Jayco 5th wheel with just under 6500 miles on it, 3000 of those miles are one round trip to the California coast and the rest on numerous trips within 30-125 miles from home.
In March and likely again in July I will be taking the rig to Phoenix which will be about 2000 miles round trip each time. The tires on the Jayco are the original Goodyear Marathons made in the Goodyear Gadsden, AL plant. The date code on the tires are 3909 which means they were made in the 39th week (September 21st) of 2009. So the tires are just over 5 years old with about 6500 miles on them and I’m getting ready to put at least another 4000 miles on them. I’ve inspected the tires very closely, there is no evidence of cracking or weather checking, they have between 6.5/32nds and 8/32nds of tread remaining on them and they have a TPMS on them.
Should I replace them? My gut tells me it’s time. My pocketbook tells me to wait. Your input is appreciated.
Dec-28-2014 06:52 PM
Road Runners wrote:
I don't know if this is relevant. Perhaps Goodyear have improved their Marathon tires. But... From 1997 till 2004 I had really bad experiences with blowouts of Marathon tires. I thought I was doing something wrong. I was told that I was probably running the wrong tire pressure or I was driving too fast and many other things.
I was finally wised up by a fellow fiver puller in a campground. He told me he had the same bad experiences with Marathon tires. He showed me his tires that he said made his tire problems disappear. I took his advice and threw away all my Marathon tires and purchased Michelin XPS rib tires. I have had no further problems with tires. I know pull my fiver with a peace of mind that I never had with Marathons.
Dec-28-2014 09:56 AM
Dec-27-2014 05:00 PM
Dec-27-2014 03:48 PM
2112 wrote:
Personally, I would have replaced them last year.
I have had a perfectly good looking tire give out on year 5. From then on they never see year 5.
Dec-27-2014 08:52 AM
Tachdriver wrote:Cummins12V98 wrote:Road Runners wrote:
That's interesting about changing the bearings. My fiver has over 110,000 miles on it and they are still the original bearings. I repack them every year and they still look good. Any opinions from others?
As long as a bearing has been serviced regularly they can easily go beyond 100K.
Regular service is the key. During service one shows sign of wear then replace.
My bearings were heat stained on my 2009. Replaced them with Timkens. Be sure to use a quality bearing if replacing.
Dec-27-2014 08:40 AM
Dec-27-2014 08:23 AM
Dec-27-2014 08:20 AM
tvman44 wrote:
You are at the limit. Just remember that if one does blow the damage could exceed the cost of a new set of tires. 🙂
Dec-27-2014 06:08 AM
Dec-27-2014 05:41 AM
Executive wrote:
You asked for opinions....here's mine.
They are speed rated at 65MPH. Assuming they were broken in properly for their first 500 miles, never run over the speed rating, never bashed up against a curb or rock, were never overloaded and generally babied all their life, they're still nearing the end of their useful life as a tire.
Dec-27-2014 05:24 AM
Dec-27-2014 05:01 AM
Dec-27-2014 04:45 AM
