On board 5th wheel generator
Franbak13
I have recently purchased a Forest River Cardinal 5th wheel and I am considering getting an on board generator. It is hooked up for generator use, but no generator.
What kind should I get? I was thinking about a 6500W but dont know that much about them.
Just need some information before I buy.
49 REPLIES 49
Lantley
Aridon wrote:
My issue with the on board propane models is they really don't last long. When we boondock we stay for 6-10 hours with the genset running more or less the entire time. That would get me about a day on the miniscule propane tanks most rigs (even larger ones) come with. Sorry but I'm not filling my tanks every day or even every other day. If you boon dock so little that isn't an issue then you likely don't need to drop 5k+ on a built in to begin with.
We are getting ready to order a DRV and we are skipping gensets this time. Going to go the Honda route, bolt them down and run them from the trucks tank. Seems an inexpensive option and more flexible to boot.
I agree lp gensets are less efficient than gas.
My rig has a 80 lbs propane capacity. On board is all about convenience. 80lbs will last on most of my 3-4 day boondocking adventures.
On board will always be more expensive and more convenient than portables. No gas cans, no set up, no additional cables or wiring. Just push a button and you have full 50 amp electric.
There are no security issues. The genset is with the fiver at all times.
If the truck goes into town the genset can remain with the fiver without security worries.
I don't boondock for long periods but I like the convenience of push button power. My rig can be totally self contained when necessary.
When we stop for lunch we have A/C and microwave available. If we overnight during the summer we have A/C available. Nothing to set up breakdown or fill.
I had a set up similar to the one I posted above. I had a Subaru 4300is inverter genset mounted on a rear platform on my prior TT.
The 4300is set up was a nice compromise between true on board and portable,however that setup was not inexpensive nor was it quite as convenient as a true onboard
There are lots of camping styles,genset options,budget, and expectations. In the end there is no one size fits all solution.
Aridon
2019 Grand Design Momentum 395
2018 Ram 3500 DRW 4.10
2014.5 DRV Atlanta (sold)
2008 Newmar 4330 (Modified) Sold
WhitehouseLV
352 wrote:
Make real sure you have a good working carbon monoxide detector. It is a matter of life or death.
A good method to mitigate against CO if you have an on board genny is to purchase and install a Genturi. You should test your CO detector too. Leaving your truck run while parked or hooked up to the fiver could cause problems.
Almsot every toyhauler comes standard with onboard generators. Not sure why they're not as popular on fifth wheels. I couldn't imagine not having a built in genny. It's nice to wake up never have to leave the RV push the switch & start it up to make coffee, warm the fiver up w/the fireplace, etc. wouldn't own another one without it. As for size. I wouldn't go less than 5500. It's nice to be able to run multiple ACs on those hot days if for no other reason cool it down faster.
Longtime Member of RV.net (since 2005) just trying to find my friends and way around in this new community.
40' Keystone Toyhauler
2017 Ram 3500 DRW
2019 KTM 300 XC-W tpi
Honda CRF 80F
Honda Rincon
Polaris RZR 800 Trail
Atom_Ant
Lantley wrote:
Atom Ant wrote:
Lantley wrote:
Hopefully photos are now viewable
Yep, they work now. Wow that is a lot of dock plate work, even the bumper. It looks great.
Is that something the fella could do himself, or did he have to go somewhere to have it made? I assume drilling holes etc is not a big deal, but the bends all look professional.
Actually it's relatively simple. The boxes were purchased and just bolted to the bumper with u clamps. Although I am concerned about the strength of the bumper. The bumper comes from the factory with the diamond plate I believe.
Once the boxes were bolted on, the gensets are just placed in the boxes and wired up.
The set up does not use a transfer switch,the RV cord simply plugs into the generators.
Sure makes a nice install!
2008 Ford F350 2014 Redwood 36RL - Our Rig
Onan 5500, Splendide Ariston W/D, 8K axles, disk brakes, G614s, tri-glide pin box,
6-pt leveling, dual heat pump, dual awnings, Trav'ler SK-1000 Dish
Lantley
rugersdad
The Onan is the way to go, very dependable and LP burns clean and you don't have to deal with gas cans. The extra cost is worth it when camping because it is much less hassle.
christopherglen
my onan 5500 runs both ac's, or 1 ac and whatever else we want. Dump some stabil in when you put fuel in the tank, start and run the generator 30-45 min a month under load (summer it is an ac, winter an electric heater, spring and fall I let them fight it out).
As far as vibration, it is about twice as much as the two ac's running, far less then the boys in the garage. Noise is slightly louder then the ac over the bed. A Genturi (or similar) is needed - no sence tempting fate, as well as the co2 detectors.
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, Titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
Atom_Ant
Lantley
gkainz
Apparently you have to be a member of the Open Range board to see the photos.
'07 Ram 2500 CTD 4x4 Quad Cab
'10 Keystone Laredo 245 5er
ol_Bombero-JC
IMO -
6500W - overkill and over weight.
Better options are/have been suggested.
Go with a single - or two - generator/s in the bed of your pickup.
Propane generators will eat LOTS of propane!
If you must have an on-board gen - 4000W designed for the gen compt
is the best option (and likely the most expensive).
BTW - you will find *LOTS* (and lots) more generator info on the Tech
Issues forum..;)
Stormyjij
I can't see the pictures...Maybe you could try to post them again?
Lantley
Photos of one of the nicest Honda 2000 installs I've seen.
The photos show how to do portables the semi permanent way.
These photos are from a member of the Open Range Forum.
I imagine this set up to be in the $3K-$3.5K range for materials
Stormyjij
Awesome thank you all, I have printed this thread and will show the hub unit.
This forum has been remarkably helpful.
-Michelle
richardcoxid
I installed A Generac 4,000W Gas RV Gen (never will I own another Generac product) then purchased a 6 gal Boat Gas tank with a quick disconnect fuel line. A couple of 2x4s wedged it in the gen compartment. I can either refill the boat tank from a "jerry can" or disconnect the fuel line and remove the whole boat tank and take it to a gas station.
2017 GMC Denali 3500 4x4 Duramax
2019 Outdoor RV (ORV) Timber Ridge 24RKS
