Pin Box Foam
prowlerregal
I saw a 5th wheel trailer at the Tampa rv show with one of these foam pin box ,I don't know what they are called.It goes on the front and both sides.It is held on the back with an elastic strap.It protects you if you walk into the pin box.Does anyone know where I can purchase one of these? Thanks.
2014 3500 SRW 4X4 Ram
2006 King of the Road Royal Villa F33TS
13 REPLIES 13
Wawhoss
My problem is the small slideout in the front bed area...you come around that corner and the slide is right at head high. A foam noodle fixed it. But u have to remember to put in place.
Fiver_Driver1
I have put a couple of plastic traffic cones beneath the pin box. You are usually looking down when you hit your head, so they are in sight.
ependydad
Old-Biscuit wrote:
https://rvsafezone.com/products/fifth-wheel-pin-cushions/
Agreed. I've had one of these now for 5+ years and absolutely love it. My fear wasn't so much of me hitting my head on the pin but more of having kids at the site and one of them clocking themselves on it.
It's held up well. Here's my review of it:
http://learntorv.com/product-review-pin-box-cover-by-rv-safe-zone/
2017 Spartan 1245 by Prime Time
2018 Ram 3500 Crew Cab DRW w/ 4.10 gears and 8' bed
FW Hitch: TrailerSaver TS3
Learn to RV- learn about RVing - Towing Planner Calculators - Family Fulltiming FB page
AUwing2
A pink swimming pool noodle cut to fit the front width of the pin box and slit to grab the edge. Bright color and effective.
laknox
Buy some cheap pool noodles and split them long-ways. Cut to length and notch the corners. Usually it'll be tight enough that you don't even have to secure it with anything. Save the extra in the storage locker, or use it to make pads for your bedroom slide corners. :B
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
prowlerregal
Thank you Old Biscuit,that's what I was looking for.
azdryheat
I just watch where I'm going.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2019 RZR 1000XP TRE
centerline
I have a length of yellow plastic safety chain that I hang from the pin box when disconnected.... when bumbling around with my head down, I may not see the pin box but I will see the chain hanging there to remind me to not go there without looking up.... sometimes when unhooked by my shop, I just place a safety cone on the ground under the pin for the same reason....
the foam block in the photo may save you from a nasty mark on the head, but its better if you can avoid it altogether...
2007 M-3705 SLC weekend warrior, 5th wheel
2014 Ram 3500 CC/LB, 6.7 Cummins
2004 Polaris Sportsman 700
2005 Polaris Sportsman 500 HO
1979 Bayliner 2556 FB Convertible Cruiser
Heavy Equipment Repair & Specialty Welding...
PapaP
Omaha Steaks.
Wife ordered a bunch of steaks and they came packed in a styrofoam box with dry ice. Went walking walking by the 5r with the box headed for the trash and thought "wait a minute..". The box fits perfectly with a slight interference fit on the pin box. No more shoulder injuries and a decent steak to boot.
Cummins12V98
Just put a foam cover on the whole darn RV and be done with it!
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
filrupmark
Nice !
I have bashed my head so many times over the years I finally learned not to do that.
2004 Ford F250 Super Duty 6.0 Diesel, Bilstein 4600 Shocks, 16K B&W Patriot, Michelin M&S
2014 Augusta Flex AF34RS Trailair Tri Glide pinbox,
JT Strong Arms , Bridgestone R250'S, KYB Monotube Gas shocks
Finally a smooth ride !!!
Lwiddis
Hang a bunch of ribbons. I do on the awning supports.
Old-Biscuit
