โDec-09-2015 09:15 AM
โDec-14-2015 05:36 PM
โDec-14-2015 12:47 PM
โDec-14-2015 11:43 AM
lawnspecialties wrote:
If I had a Sherline set up to go underneath the pin, is there some kind of physical way of cutting the weight in half for the scale? In other words, how can I set it up so the weight on the scale is half the true pin weight and a 2000 lb. rated Sherline will handle it?
โDec-10-2015 10:04 AM
โDec-10-2015 10:00 AM
โDec-10-2015 09:52 AM
12thgenusa wrote:
Here's why a "rule of thumb" really doesn't work.
The GVWR of my trailer is a shade under 10k. If I am ultra conservative and use 25% to calculate pin weight I am at 2500#. However, I load to a GVW of only 8400# and my pin weight is only 15% empty or loaded. So my real pin weight when traveling is only 1260# or approximately half of the conservative guess.
A "guess" of 2500# would totally rule out a perfectly good trailer for me to tow. Likewise, if you guess wrong on the other direction you could be way beyond the capabilities of your TV.
I understand the dilemma. It is more critical for those with conservative tow vehicles. It is not always possible, realistic or desirable to just go get a bigger truck.
I spent considerable time studying brochures and making calculations before I bought my present trailer. It was time well spent. It has been a great combo and has served me well.
โDec-10-2015 08:53 AM
ford truck guy wrote:laknox wrote:ford truck guy wrote:
Perhaps I am wrong here??? BUT I thought this was about a guy looking to BUY a new camper.. There are 2 issues -
#1- who actually loads their possible new camper on the dealers lot just to see the weight???
#2- what dealer in their right mind will allow someone looking at trailers to load one up , then get it weighted ???
That's WHY you go by the GVW and the worse case scenario ..
The problem is that you don't know what, and how much, "stuff" you're going to be carrying. Also, the mfrs are =very= reluctant to release plumbing schematics so we can know where the tanks are supposed to be. If I knew where my fresh water tank is located, the one that's most likely to be filled when traveling, I could use it for ballast to offset a heavy pin, especially if it's somewhat behind the axles. As others have said, the pin wt ratio can drastically change as you load up.
Lyle
Lyle , I agree with you... BUT-
I don't know of any dealer that will allow you to fill the camper UP with your stuff AND take it to get weighted.... That's a huge liability ....that's why you need to go off the worse case , if your truck can't do it , go bigger...
โDec-10-2015 08:11 AM
Lyle
โDec-10-2015 07:40 AM
โDec-10-2015 07:24 AM
โDec-10-2015 03:30 AM
Lantley wrote:Old-Biscuit wrote:Super_Dave wrote:
If exact is really important, aren't you still guessing what wet weight will be?
Exactly........
The OP can weigh any rig he is interested in. If he wants to load it up with cargo he can do that as well. The OP can carry his experiment as far as he wishes to take it. With the scale his weight can be as exact as he cares to make it.
In the end his scale weight will me more accurate than just using brochures and stickers.
โDec-10-2015 03:29 AM
โDec-10-2015 02:56 AM
Exactly........
โDec-09-2015 08:19 PM
โDec-09-2015 07:41 PM
