Pullrite super glide hitch, looking for bed pins
paulinemay
We've lost the pins for our glide hitch that secure the hitch to the truck bed. Pullrite only sells them as part of the mounting kit, from what we can tell. Anyone have any ideas?
TIA.
11 REPLIES 11
ol_Bombero-JC
kennethwooster wrote:
Always good to help a fellow rver. Hopefully we are hopefully that helpful.
Hopefully -since the OP now has the pins..:C.. - hopefully the Mods can close the thread...;)
kennethwooster
kenneth wooster- retired farmer. Biblical History Teacher in public HS, and substitute teacher.
wife Diana-adult probation officer, now retired.
31KSLS Full Body paint Cameo
Ford F350 2014 DRW 4X4 King Ranch.
20K B&W Puck mount hitch
paulinemay
Thanks, all, for your input-- especially you, Banjo, for getting these out to us. Got the tracking number on your message. Much appreciated!
Hvyhauler
parkdep wrote:
PullRite Hitch Bed Pins
Good info... thanks for posting the link.
2006 Dodge 3500 DRW SLT 4x4 LB QC CTD PullRite SuperGlide
2007 Mountaineer 336RLT Mich. XPS Ribs Duro Max XP4400E Gen.
2000 Lance 1130 Torklifts/SL/Stainless Generac Gen.
2 Rescued Camping Collies (always ready to go)
banjo
Pauline, ..... Pins sent.
Banjo
2011 3500 DRW D/A CC LB 4X4
2011 Cameo 34SB3
parkdep
RollandB
The large pins securing the hitch to the bed can be purchased from Pullright. I purchased a used 3300 this past summer that didn't have them. I believe all 4 were about $100.
2013 Yukon
2021 Coachmen Spirit 1943RB
banjo
Hello Paulinemay
Sent you a PM. I have the posts (pins) you need.
Contact me soon. Leaving for a Bluegrass Festival Thursday.
Banjo
2011 Cameo 34SB3
Hvyhauler
n7bsn wrote:
I expect the pins in question are NOT conventional hitch pins; ie the ones that connect the bed-pins to the hitch.
The bed pins are probably only available from PullRite
Good point... if the op is referring to the large "rail" mounting pins (4 each) which go through the truck bed into the underbody mounts... these will definitely be a Pullrite only part.
Still... call Pullrite and explain what parts you need. They have great customer service & will work with you.
n7bsn
2008 F350SD V10 with an 2012 Arctic Fox 29-5E
When someone tells you to buy the same rig they own, listen, they might be right. When they tell you to buy a different rig then they own, really pay attention, they probably know something you don't.
Hvyhauler
I would call Pullrite and talk to Leslie in the parts dept, I'm sure these can be purchased individually with the retaining clips.
Tractor Supply also sells this type pin for about $2.25 each... retaining clip included.
Any farm/agriculture/country hardware type supply house will have these pins.
