24fb freedom wrote:
Thanks for posting this, I have a superglide also and will be calling pullrite as mine does not have the castle nut and pin.
Be worth knowing *WHICH MODELS* of SGs have the castle nut - or should/can have a castle nut...:?
From SG Owners Manual:
2300 and 2700 models have a castle nut and pin in the roller assembly. To re-torque, tighten roller bolt to a minimum of 125 ft lbs, then tighten more until next nut slot aligns with the stud cotter pin hole . Install cotter pin and bend one leg upward."
Will check my #3300 (from 2005) - which was the older design way tubes, and update (as there's nothing similar in the Owner's manual).
