Question about stabilizers
scootsk
Just installed my stabilizers. Love them, eliminated all the "shake" in the fifth wheel. Yahoo. Just one question, I was looking at them the other day and I noticed that when I put up the landing gear the t-handles will hit the frame and prevent the landing gear from retracting all the way. I want to reverse the install and have the t-handles facing down. Has anybody done this? Will this increase my chances of losing a handle during travel?
Don, Kathleen
2014 Ram 3500 Crew Cab 4x4 Dually 6.7 CTD/AISIN
2019 Montana 3791 Fifth Wheel
15 REPLIES 15
Cummins12V98
I have the 4 point hydraulic landing gear on our Mobile Suites and see no need to add stabilizers.
Could be because they come down at an outward angle.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
PennyPA
Why do you have to retract your landing gear all the way in the first place??? We never retract ours all the way. Doesn't your fiver have an outer leg that comes down a distance when you push a button and then you lower the inner leg (with the holes in it) to whatever height you want them?
COPD and LVRS
On the Road Again
My Home - 2002 Glendale Titanium, 32/37DS with a basement slide.
Our Home's Leader - Dodge Ram 3500 Cummins Turbo Diesel Dually
Our Leaders - Sam(Bird), Chirp(Bird), Nellie(FAT cat), Lucy(Kitten), Willie(Dog) & Daisy(Dog)
shadows4
This is one of the reasons I bought the BAL stabilizers, they use the same 3/4" size bolt that my rear scissor jacks use. I just tighten them with the same crank I use on the rear jacks. And the bolt sticks out the side. As to the OPer, I would think it would work fine to flip them over. Saw a post on here where someone drilled a small hole in the t-handle and wired them so they wouldn't come all the way out. Good luck, John
2016 4X4 F350,CC,SB,Lariat,6.7L diesel,
2015 Coachmen Chapparal 324 TSRK
B&W Patriot 16K hitch.
jims1
You can drill a hole thru the leg or thru the foot. It won't hurt either to do so.
Volvo dually Pickup
DRV Memphis
Me, Alie, and Salie
Fulltiming
scootsk
I've read that people have had a tab welded to the hydraulic landing gear so that they could bolt the stabilizer to the non pinned leg. I have the Eliminators and believe a vertical tab welded to your landing gear would work fine.
Don, Kathleen
Halmfamily
Looking at Scoots picture above his mounts into the holes on his landing gear. Mine are straight hydraulic rams with no holes just a 10" landing pad at the end. Is there a clamp that does around the bottom of the hydraulic ram above the pad?
2008 GMC Sierra 3500 SLT DRW D/A 4x4 (Big All)
2006 Ford F350 PSD SRW King Ranch 4x4 (Henry) (Sold)
B&W Companion, 90 Aux Fuel Tank, Scan Gauge II, Curt f/m hitch, Swagman XC
2015 Forest River Sierra 360 PDEK
DW Diane, DS Michael, FB Draco and Sabian
scootsk
How are the legs different on the hydraulic? I don't think it would make a difference as long as the bracket can bolt onto the landing gear.
Don, Kathleen
Halmfamily
Do they make to fit hydraulic landing gear? I always see them pictured on the electric type. Any and all suggestions appreciated.
restlesswind
No way to modify them to have the T handle on the side?
Mine (SOB) has 3/4 bolt on the side that I can tighten using a ratchet with
an 18" extension. Nice not needing to get down on one knee to tighten them.
I would sure try to figure out some way to modify those that you have,along with fabricating some sort of tool to tighten the T handles.(Or use short bolts in place of the T handles.
'04 33.5 CKQG Hitchhiker Discover America
04.5 Dodge 3500 CTD SRW
Pac Brake,Max Brake
Fulltimers since '06
scootsk
JohnBoyToo wrote:
Is it life threatening if you don't retract all the way ????
Many times I've seen 5er's with them not completely retracted...
I know, I know, it 'could' hit something and understand it if we were going off roading or railroad track climbing 🙂
but that's only a problem if you are not aware of what your are driving over - just like paying attention to height limits, correct ?!?
Why chance it if its not necessary. Putting the t-handles on the bottom is easy, just need to know if anybody has had problems doing this. At 13'4" I do need to worry about height but why would I want to worry about the landing gear, if its not necessary. If I was told that turning the stabilizers over would cause a great deal of grieg, I would leave them alone and worry about my ground clearance.
Don, Kathleen
JohnBoyToo
jjj
I have the same problem. I am working on changing the way they mount to the frame so the handle will be on the side so it is easier to use.. I think they need to change their design for easier use. They come with those metal brackets that attach to the frame and I am going to drill a hole on the side of it and run the securing bolt through that and attach the stabilizer to it and the handle will change position to the side. I hope.
2002 F-350 Crew-Cab Dually
V-10-4.30 gears Mag-Hytec diff.cover
w/Amsoil-6.0 trans cooler Curt Q5 20K hitch & bedsaver
2005 Keystone Challenger 34TBH-Fifth Airbourn
ependydad
I ordered 4 extra t-handles, just in case I lose any- I keep them in my random spare parts bin.
But, the nice part about the t-handles - while nice, they aren't a required thing to enjoy your trip. If you lose one and don't have a replacement, you simply live with some extra shake (unless someone is severely motion sensitive).
2017 Spartan 1245 by Prime Time
2018 Ram 3500 Crew Cab DRW w/ 4.10 gears and 8' bed
FW Hitch: TrailerSaver TS3
Learn to RV- learn about RVing - Towing Planner Calculators - Family Fulltiming FB page
fj12ryder
I had to put my rear stabilizers on upside down. As long as you don't forget to snug them down before traveling you shouldn't have any problems. And if you lose one it's no big deal, it's just a standard bolt size: 3/8-16 I believe.
Howard and Peggy
"Don't Panic"
