Refreshing fiberglas
5th_wheel_trave
Does anyone know of a detail shop or any repair shop that can revitalize the fiberglas on my 2000 Excel fifth wheel? I have some areas showing oxidization and the finish is dull. I don't know if it is repairable or can be fixed by a good detail shop. I live in the Milwaukie, OR area but would be willing to travel some for a good job.
18 REPLIES 18
blofgren
ckwizard777 wrote:
I got tired of standing on the ladder just to polish the front and rear caps all the time so I had them clear coated last year.
Shiney all the time now.
Interesting; did you have any prep done on the caps before they were done? And did you have this done at a body shop? I would be very interested in getting this done as well.
2013 Ram 3500 Megacab DRW Laramie 4x4, 6.7L Cummins, G56, 3.73, Maximum Steel, black lthr, B&W RVK3670 hitch, Retrax, Linex, and a bunch of options incl. cargo camera
2008 Corsair Excella Platinum 34.5 CKTS fifth wheel with winter package & disc brakes
kkuhl
meguiars cleaner wax will bring out the shine.i apply remove with buffer w/microfiber pad. donot use a grinder with buffer pad will burn surface if not careful.
tartan_camper
I use Meguiar's 49 Oxidation Remover. I bought it at a boat dealer and it works very well! Cost me $12.95 for a 16oz bottle.
Backpack to fiver...and everything in between. What a life!
2018 Grand Design Reflection 303RLS 5th Wheel
2015 Chevrolet Silverado 2500HD Duramax, Allison 6-speed
18k Superglide
buta4
Bowti wrote:
Terryallan wrote:
Bowti wrote:
Terryallan wrote:
Best way to bring back the shine. Water sand it with 500+ grit water paper. then buff, and wax.
however try a good Cleaner Wax first. May be all it needs
500 grit wet sanding is too aggressive, better to be in the 1000, 1200, or 1500 range before buffing. Of course everyone differs some what on this, depending on surface condition, rubbing compounds used, and expected finish desired.
I would not recommend wet sanding for someone who has not had experience or training in it.
I did it for a living. I was the "Boat Doctor". and truly we used 400 grit Water paper. which is way different than regular sand paper. Then I buffed if out with compound, and waxed it. I have to brag a little. When I was done. you couldn't tell it was ever scratched, or dulled. And when a new boat was drilled wrong.. You couldn't see the bad place when I was done.
I also rebuilt molds for new boats. they had to have prefect finishes. Because the GelCoat goes on first. The fiberglass is sprayed / chopped, to the GelCoat.
Now, you are saying to wet sand with 400 grit and then buff. I stand with my original statement, we are talking about finishes on rv's.
So can you tell me how fiberglass on boats is different from fiberglass on RV's?
Ray
jstar
I wouldn't recommend wet sanding unless its really in bad shape, test with rubbing compound first if that isn't enough then go with 1000 to 1500 emory cloth which is wet sand paper.
jstar
Fulltimers
ksbowman wrote:
The black paper that is called wet or dry sand paper. I always use it with water though.
OK. I am familiar with Wet or Dry sand paper but never heard it called Water paper before.
Fulltimers
Fulltimers Weblog
2003 Rexhall Aerbus 3550BSL
W-22 Workhorse
2005 Saturn Vue (Mr. Toad)
3.5L V6 Automatic
Bowti
2013 Keystone Cougar 28SGS Xlite
Shipping weight 7561 lbs
Carrying capacity 2439 lbs
Hitch Pin 1410 lbs
2008 Silverado 2500 Duramax 4X4 Crew Cab
Reese 16K Round Tube Slider
Custom 3 Receiver Hitch Scooter Carrier
2013 Honda PCX Scooter on the Carrier
blacktop
Star Brite and hard work.
ksbowman
Fulltimers
What is Water paper?
Fulltimers
Fulltimers Weblog
W-22 Workhorse
3.5L V6 Automatic
Terryallan
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
ckwizard777
Ken & Deb
2008 Montana 3400
2007 Chevy 3500HD CC,LB Dually 8.1
Bowti
Hitch Pin 1410 lbs
RAS43
If you don't want to try to repair it yourself as others are suggesting then ask a couple of RV dealers where they send such work. Or find a commercial truck/trailer repair shop and ask them.
