Replace landig gear disney world rv park
Usnthedog
Any recomended mobile rv repair that can repair or replace the front landing jacks on a 5er, within wdw wilderness cg. I broke the verticle threaded shaft in one side. Atwood and obsolete so it probably will take a new set. Must be done on site.
Thanks
Jeff
6 REPLIES 6
heaterswa
Camping World is nearby Fort Wilderness / WDW.
Besides the other two suggestions you could check there.
10 years or so ago had to go there one morning to get a new AC unit and popped it in myself.
Me, Wife, 3 daughters, and a woof woof
TV: 06 GMC 2500HD D/A SLT 4WD / Prodigy / Reese Signature 18K
FW: 07 KZ Durango 315BH / Fifth Airborne / Sidewinder / JT Strong Arm Stabilizers
jerem0621
Buddy of mine did that same thing in the same place. We ended up on big scissor jacks and jack stands for the trip and had the legs fixed at home.
Big Bottle jack, giant jack stands under the frame of the fiver. Worked great. Google Harbor freight...I think there is one 30-40 minutes away from you.
You
TV-2022 Silverado 2WD
TT - Zinger 270BH
WD Hitch- HaulMaster 1,000 lb Round Bar
Dual Friction bar sway control
Itโ€™s Kind of Fun to do the Impossible
~Walt Disney~
Mike_Boutet
Dave in TN wrote:
Here's a couple of mobile RV techs that are recommended over at the FortFiends.net site:
Franks Mobile RV
407-922-7302
Master RV Mobile Services
407.348.0862
X2 Franks Mobile rv
Usnthedog
mtofell1 wrote:
Are you sure it's not just the cross bar that feeds power from the motor to the other side? A super common failure is the bolt in the cross bar. It's actually a planned failure point. I carry spare bolts just in case.
I was looking on etrailer recently and seem to remember you could buy an entire setup - jacks, motor and hardware for a few hundred dollars so hopefully this won't cost a fortune if you do need some/all of the parts replaced.
Sorry, I don't know of anyone in that area.
No. It appears that the bearing holding the verticle shaft(the acme threaded rod) failed and allowed the shaft to rub on the housing. Wore enough to weaken the shaft and it sheared off. I have the driven bevel gear in my hand witk a piece of shaft. I wish you were right.
Dave_in_TN
Franks Mobile RV
407-922-7302
407.348.0862
Dave & Christy / 5 Awesome Girls (28,26,24, 18 and 16)
2021 Grand Design Solitude 378MBS
2019 Ford F-350 SRW 6.7
mtofell1
