Mar-09-2015 12:28 PM
Mar-10-2015 04:20 PM
Mar-10-2015 04:11 PM
Mar-10-2015 03:19 PM
Mar-10-2015 03:12 PM
robrose1 wrote:
Bought the Carlisle radial trail RH last year in e rating . So far I am very happy with them. Rig has been in storage since sept., last week I bought it home to clean and the tires still had 80 psi in them.
Mar-10-2015 02:30 PM
laknox wrote:sarhvac1 wrote:
I know this is beat to death however I have 225/75r15 tires with a d rating @65psi looking to replace I know every one on here is LT positive however everything I look at in LT doesn't really have a 15" I should say all the ones recommended on here and the ones that do have a higher pressure rating// question is will rim design be able to handle this? also talked to rv dealer where we bought unit and a tire guy both think the new Carlisle USA trail are the way to go?? NEW is what I'm wondering about
I upgraded from the placarded D tires to E tires on my 11,300 GVW FW. I had to make sure that my Al rims were rated to 80 psi, which they are, and are stamped on the back side. That's your first step; check the rating on your rims. You might have to dismount a tire, though, as some are stamped in the valley =inside= the tire. I suspect that Komfort simply used the same Al rims on all their 10k+ trailers. If your rims are steel, I'd bet that they are only 65 psi and you'll have to change to heavier rims to handle E tires. If they're Al, you may be in the same boat as I am. I am going into the 3rd year with my Carlisle RHs and, so far, they're working well. I don't put a lot of miles on them, store the FW on boards and keep the tires covered. They're just starting to show some weather checking.
Lyle
Mar-10-2015 09:56 AM
Mar-10-2015 09:24 AM
Mar-10-2015 08:04 AM
Mar-10-2015 06:43 AM
Mar-10-2015 06:01 AM
sarhvac1 wrote:
i have the towmax on the trailer since new probably close to 20k miles on them they are just starting to show signs of wear center rib on 1 looks like getting bald never had a problem or any issues with the towmax but again my rims have 65 psi tires on them will they hold 80psi?? i will call keystone today see if they actually answer the question.
Mar-10-2015 05:58 AM
kohai wrote:
I'm in a similar situation. I think I have 15" wheels on my trailer because the 16" were an upgrade. My max trailer weight is 11,472. 11472/4 tires = 2,868.
The max weight for the 15" maxiss and carlisle is 2,830. LT tires aren't made for 15" that I have seen.
Is the trailer mfg assuming a % of weight to be on the truck so they can get by with 2,830?
I still have the original tires on the trailer and the psi written on the side of the trailer is 110 lbs (or maybe that is the torque).
Mar-10-2015 05:39 AM
NMDriver wrote:
16 inch tires are between 31 & 32 inches in diameter. 15s are around 27-28.
Mar-10-2015 04:49 AM
Mar-09-2015 08:11 PM
