Dec-16-2013 04:51 PM
Dec-18-2013 12:09 PM
wtmtnhiker wrote:
Hi all,
I have a 37' 5ver that has a big bubble in one of the tires. I replaced 2 tires last year and I still have 2 to do. The trailer has Mor Ryde suspension. Does anyone know the proper procedure for replacing just 2 tires? I was recently told by the Goodyear dealer that I should put the 2 new ones on the same side and have the two used ones on the same side. He said that even a small difference in the tread depth would cause the new tire to carry more of the load, thus uneven load distribution. I can't picture that with the suspension I have. Any input?
Dec-18-2013 05:19 AM
rattleNsmoke wrote:
I would think to put the new(er) tires on the axle bearing the most weight. That would require a trip to the CAT scales to see the difference.
Dec-18-2013 04:40 AM
Dec-17-2013 10:12 AM
JIMNLIN wrote:Francesca Knowles wrote:JIMNLIN wrote:
Its best to have the new tires on the same axle for equal braking especially on wet pavement.
I'm having trouble understanding this statement. Why would having the new tires on one side as recommended by the dealer result in poorer braking?
The brakes on one axle get the same amount of amps when braking. If one end on the axle has a new tire and the other end has a old tire the old tire can/may slide easier than the new tire. Wet pavement simply multiplies the problem.
Read carefully what Goodyear is saying about "handling and performance".
Due to braking rotational forces during a hard braking event the rear axle can lift the front axle, through the equalizer bar, enough that the front axle tires can slide. Results are flat spotting. For that reason I prefer my new tires on the rear axle.
Other may prefer the front axle.
Dec-17-2013 04:31 AM
Dec-17-2013 04:20 AM
JIMNLIN wrote:
Goodyear says this in there RV website;
Mixing tire types and sizes.
When you mix tires of different constructions, sizes and depth of tread wear, it can affect handling and performance. Goodyear recommends using the same size and type of tire on the same axle – i.e., all radial ply or all bias ply, all the same size and all the same tread pattern – as well as maintaining your tires so that they all have approximately the same depth of wear.
Dec-17-2013 02:58 AM
Dec-16-2013 11:13 PM
Dec-16-2013 05:32 PM
Dec-16-2013 04:56 PM
