replacing weather-stripping on 1999 Carri-Lite slide out
S_Louise
We need to replace the weather-strip seal around the outside of our slide out -- our 5th wheel is a 1999 Carriage Carri-Lite (529RK). I'd like to do the replacement myself but am having trouble locating the correct item. I believe it's called a side bulb trim seal but it needs to have a 90-degree bend radius without the risk of leaking. Any ideas would be greatly appreciated. Thanks!
5 REPLIES 5
dave_smith1
Just did this myself. Got a 30' roll from Amazon...worked fine (except black instead of dirty white).
DS
Regards,
Dave & Kristi Smith
2013 Arctic Fox 29-5K FW
2011 Ford F350 Lariat
Visit our RV site!
S_Louise
I appreciate the referrals & links -- thanks much! Have a great, safe Memorial Day.
TXiceman
Call Kansas RV Center in Chanute, KS. This is the repair shop that used to build NuWa HitchHikers, They may have the seal you need.
Or check on the Lifestyle/Carriage forum on the internet.
Ken
Amateur Radio Operator.
2023 Cougar 22MLS, toted with a 2022, F150, 3.5L EcoBoost, Crewcab, Max Tow, FORMER Full Time RVer. Travel with a standard schnauzer and a Timneh African Gray parrot
bobsallyh
https://www.pellandent.com
https://www.trimlok.com/default.aspx
http://parkin-acc.com/page39.html
https://www.steelerubber.com/wiper-seal-slide-out
http://www.cleanseal.com/
https://uni-grip.com/
These are the outfits I have listed. Most, you have to buy a roll, etc. but much cheaper than an RV joint. I got ours thru Pellandent, were good folks to work with. Just try to match yours up with one of these vendors.
agesilaus
I usually find that taking the part to a local RV dealer parts dept will produce the part
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
