Residential refrigerator
stevewise
I just bought a new 5er with a residential refrigerator, it has a 1000 watt inverter. I tried to run the refrigerator off the inverter yesterday and it did not appear to be working, the light was on, on the inverter switch, but when I opened the door of the refrigerator the light did not come on. I know with a house refrigerator if the light does not come on then there is no power.
Any suggestions would be helpful
'15 Sierra 377FLIK
'14 Ford F350 SRW King Ranch
DW and Cricket the Chihuahua
23 REPLIES 23
dapperdan
naturist wrote:
I would very much doubt any residential refrigerator would run off a mere 1,000 watt inverter. While such a unit might only draw 600-700 watts while running, the starting surge would be in the neighborhood of 2,000 watts, way beyond the capacity of that inverter. A 1500 watt inverter MIGHT have enough surge capacity, but not a 1,000 watt inverter.
Our Mobile Suites came with a 1,000 watt inverter, 2 6v golf cart batteries and a Whirlpool residential fridge, works great!
Sounds like a breaker may be tripped, I'd call the dealer or take it back to them and have it checked.
Dan
wm5e
Mine is mounted on the ceiling of the basement on the drivers side.
John___Angela
stevewise wrote:
Thanks for all the advice but when I tried to locate the inverter I could not find it. I called the service guys and they had me check some places but to no avail. So they booked it into the shop to get it repaired. (It is still in warranty)
It'll be somewhere close to the battery.
2003 Revolution 40C Class A. Electric smart car as a Toad on a smart car trailer
Life is not measured by the number of breaths we take but rather by the moments that take our breath away.
GrumpyandGrandm
Call the manufacturer and ask them.
Grandma in front of her retirement home..
She lets Grumpy drive!!
stevewise
'15 Sierra 377FLIK
Racine96
I have one with a Samsumg residential refrigerator, it works well. However, initially it did not. The inverter was wrongly connected and did not work. The dealer changed the way it had been wired and has worked fine for the last year. I love it.
pcm1959
The Samsung units use very little power - even at start-up. We have a GoPower PSW 1000 watt inverter with 2 group 24 deep cycle 6 volt batteries. This combo pre-cools our frige in 90+ degree FL heat to 0/37 degrees in about 3 hours with 2/3 battery level in reserve. At that point, we load up and leave and the truck keeps the batteries from discharging any lower during our trip. we have had the residential set-up since August and LOVE it.
2018 GMC Sierra 3500 DRW 4x4 Duramax/Allison
2014 Lifestyle LS36FW
St Augustine, FL
RustyJC
Many of them are operating just fine with 1000 watt inverters. The standard inverter DRV supplies with a residential fridge is a 1000 watt. They have a larger inverter and larger coach battery system with 2 additional 6VDC batteries as an option to power more appliances in addition to the residential fridge. The 1500 watt PSW inverter in our DRV is more than is needed to power the residential fridge - it's been doing it just fine since we took delivery in May 2014.
Rusty
2014.5 DRV Mobile Suites 38RSSA #6972
2016 Ram 3500 Dually Longhorn Crew Cab Long Bed, 4x4, 385/900 Cummins, Aisin AS69RC, 4.10, 39K+ GCWR, 30K+ trailer tow rating, 14K GVWR
B&W RVK3600
GrumpyandGrandm
The SAMSUNG 18 cu-ft French door that JAYCO uses only draws 3.9 amps. Works great with a 1000 watt inverter.
Travlingman
lanerd wrote:
Your inverter may have a circuit breaker on it. Check all visible sides of it...most are push button type of a breaker.
Also, when you say fully charged, do you mean 12.6 volts?
good luck
Ron
x2 on check the reset on the inverter itself.
2017 F-350 King Ranch DRW
2014 Landmark Savannah(sold)
2022 DRV Mobile Suite 40KSSB4
lanerd
good luck
Ron
Ron & Sandie
2013 Tiffin Phaeton 42LH Cummins ISL 400hp
Toad: 2011 GMC Terrain SLT2
Tow Bar: Sterling AT
Toad Brakes: Unified by U.S. Gear
TPMS: Pressure Pro
Member of: GS, FMCA, Allegro
RETIRED!! How sweet it is....
time2roll
OK now follow the power. Check voltage on the inverter input is above 12.5 then check inverter output is 120vac. Then check if the fridge outlet is getting 120vac.
Somewhere there will be power on one side and no power on the other side of something.
2oldman
Do other 120v items work?
stevewise
The battery is fully charged
'15 Sierra 377FLIK
