rims again
lee_worsdell
I just noticed after a year that my spare is an 8 bolt and the trailer is 6,will this still fit over the 6 bolt pattern or did they screw up at the factory
8 REPLIES 8
laknox
JIMNLIN wrote:
Sometimes a equipment/utility/enclosed trailer dealer or a farm store can fix you up with a proper wheel that fits your trailers lug pattern.
Just make sure a rookie tire dealer doesn't sell you a 6 lug non trailer wheel.
YES! Your wheels are almost certainly zero-offset, so you need to replace with the same.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
JIMNLIN
Sport45
They may trade straight up for a take-off. The 8-lug is likely to be a heavier rated rim than a 6-lug.
โ€™19 F350 SRW CCLB PSD Fx4
'00 F250, CC SWB 4x2, V-10 3.73LS. (sold)
'83 F100 SWB 4x2, 302 AOD 3.55. (parked)
'05 GMC Envoy 4x2 4.2 3.73L.
'12 Edge 2.0 Ecoboost
'15 Cherokee Trailhawk
lee_worsdell
it was hanging from under the front thru the center hole. I have been dragging this dam thing around all over in the back of the truck and it wouldn't work any way lol. I bought the trailer at rv nation a year ago iam up in Canada so guess I will just go to local tire store buy a new rim
darsben
or someone at the dealer needed a tire quickly and "borrowed" yours then replaced it later.
Check the date code on the tire you may be able to tell the story by the date code.
Traveling with my best friend my wife!
Sport45
So it hangs from the center hole, makes sense.
I'd see if the outfit you bought it from will change it out for you.
lee_worsdell
never had a flat I took it off the bottom of the trailer to put on jt strongarms its brand new
Sport45
Sounds like somebody screwed up.
An 8-bolt wheel might not even fit the same spare tire carrier as a 6-bolt.
