Roadside Slide Failed
ThePostman
We bought a new 2015 fiver in February and love everything about it except the apparent negligence that went into building it. Its almost as if the factory told the engineers and craftsmen that after they built my unit they were going to be fired and then the factory burnt the build sheets. But I won't bore you with the past.
A week or so ago the long roadside slide, maybe about 20' long, started making lots of noise. I called a local dealer to come out and check it and made an appointment to get the RV in and repaired. Long story short, after about a week of seeing what the next failed part was going to be it turned out that one gear pack was completely stripped with the other two damaged. The weld on the middle rail of three had broken and one of the three rails had twisted. For those who don't know the way this works is that there are three rails with three gear packs that are tied together so that when one is pushed (or pulled) the other two turn with it. The push (and pull) is performed by a hydraulic cylinder.
For all you engineers out there, where would you put the hydraulic cylinder on a slide that is maybe 20' long with a French Door domestic refrigerator and a floor to ceiling pantry next to it and a TV on the other end? If you said that the hydraulic cylinder would be placed at a point determined to be the center of the weight on the slide you would be wrong. If you said that the hydraulic cylinder would be placed at the center of the slide you would be wrong. The hydraulic cylinder was placed about halfway between the rail at the opposite end of the slide from the refrigerator and pantry and the end of the slide. Its not even between the rails. Its about as far towards the end of the slide as it could possibly be installed.
Now am I crazy or would just about any reasonable person think that putting the hydraulic cylinder at the opposite end of the weight is a prescription for problems? Has anyone else had problems with a set up like this? Has anyone else have a similar system that works for them?
Thanks,
17 REPLIES 17
ThePostman
taken wrote:
The design of having one hydraulic ram at one end (whether it's the heavy end or not, it's usually in the front) is completely normal. There is a shaft connecting the two gear packs keeping them turning at the same time. So, while it may look crazy, it's used all over the industry.
The washer trick is a band aid cure for a slide that is out of height adjustment. If the slide is adjusted correctly there should always be enough down force to keep the gear pack and the idler gears in mesh. The heads at the end of the idler tubes need to be adjusted down to increase the pressure on the idler tube while it is in motion going in and out. If Lippert advised anyone to do this, it's because they knew that telling them how to correctly adjust the slide would take time and if you don't do it correctly, you could throw things further out of adjustment.
What's causing the problem with your out of height adjustment scenario is, as the slide goes in, the weight of the slide is coming off the tubes too soon transferring to the floor of the RV. This is what's unloading the idler tubes and causing them to jump gears. If you look at the outside of your slide where your idler tubes meet the slide cross rail you will find the two adjustable heads. Each will have two bolts and nuts over slotted holes. The nuts/bolts lock them in place but when loosened can allow the head to slide up or down. Below the head is a long bolt with a set nut. This long bolt will raise or lower the head when it's set nut and the two previously mentioned nuts/bolts are loose.
Last summer my new rig had this very problem. When I brought it back to XLR to get it straightened out I talked extensively with one of Lippert's main techs who came to the plant to address my issue. He told me Lippert knows about the washer trick and they've also seen the gears cut off the bottom of the idler tube and welded on lower to try to scab a cure. None of this is correct. There is only one correct way and that is to align the slide in the trailer correctly. He said dealers, mobile techs, and do it yourselfers do this type of repair ALL the time but it just isn't the right way to do it and will likely lead to another failure in the future due to moving the stress to an area that it's not meant to be. He said he's always shocked that people go to such lengths to correct something but completely ignore the adjustments that are built into the system to cure this very issue...
That all makes sense. My understanding is that with ours, BTW the plunger is about 3' from the back of the slide, one of the rails, maybe the middle rail, was not perfectly square with the frame and gear pack causing the gears to wear. With that said it still makes no sense to me that the plunger would be placed at one end or the other of the slide when there is room at the center and its even closer to the pump.
Thanks for your reply.
taken
Regards, Rodney
TV - 2017 F350 SRW CC SB 4X4 6.7
TH - 2015 FR XLR 395AMP
Peg_Leg
Ok these are the pic Joe sent me and ask if I could post them here.
view of where you need to place the washer for the stripped gear fix.
You can see the washer between the two tubes. Ideally I'd like to tack weld it in place. I will try this fix away from home so I'm going to try a small amount JB Weld in the washer hole and around the edges. I'll lay the washer on some wax paper and slide it into the gap. May have to use some paper shims until the JB Weld sets up.
[URL]
Tnx to Joe for the pics. Should have put jwakeman.
2012 Chevy 3500HD Dually 4X4
Crew Cab long bed 6.0 gasser 4.10
2019 Open Range OF337RLS
Yamaha EF3000iSE
retired gadgetman
Endricken
FYI, for Hydraulics (one pump services all slides), the easiest goes out first and the hardest last - with sometimes the "hardest" moving a little while the easier one gets finished. Of course the smallest, lightest, Bedroom slide moves out completely before the big slides even start.
Retired USAF
Silver 05 Dodge RAM LB CTD Dually 4Speed Auto SWD 3.73, Westin Sportsman Grill & Taillight Guards,Husky Mudguards, Retractable Ball Hitch, Onboard Air & Horns, MaxBrake - towing 2005 Keystone Montana Big Sky 3670 with Star Performance adapter
Peg_Leg
Tnx for the info, jwakeman. Now I hope I can keep my senior moments at bay and remember this until I get to FL. Then I'll have time and better weather to investigate the shim fix. Replacing the gear is not all that hard, it's opening the bottom for access that's a pain. I always keep an extra gear on hand.
Yamaha EF3000iSE
retired gadgetman
wvcampers
Our Cardinal has one ram on each slide. Not sure that two rams could be synchronized. My front legs are also hydraulic and they operate with one switch. They do not drop or retract at the same time. The 3 slides operate with one switch and the one with less resistance is the one that moves. Most of the time one will partially extend then another will extend a little. They do this until they all are completely extended. So I don't see how 2 rams on one slide would move it evenly.
2017 F350 6.7 CC Lariat DRW
2018 Cardinal Luxury Edition 3250 RLX
ThePostman
No need to be sorry. Senior moments are a part of who I am.
jwakeman
Hi folks I realized this AM that I had a senior moment yesterday. So sorry. I have only 1 ram with 2 gear tracks guides I was describing as rams. The problem is the top of one gear guide racks has a 1/16 inch slop in it that allows the gear track to jump and bust a gear.
Put the washer in the top of the guide channel to take out the slop.
Again sorry for the confusion.
2013 Silverado LT 2500HD 4X4 crew Cab Duramax Diesel/Alison
2016 Montana 3721
ThePostman
wvcampers wrote:
The rams on my Cardinal are not in the center of the slides. I have not had any problems with the slides. I do have the fridge in one slide but not as large as yours. The Cardinal is 08 and gets lots of use.
Thank you for that. Do you have two rams? Ours has only one that is outside of the three gear rails about 3' from one end of the slide and about 17' from the other end.
wvcampers
ThePostman
laknox wrote:
ThePostman wrote:
jwakeman wrote:
Yes it is lippert. The front rams is in about a foot and the back is in about 3 foot. I am unable to locate the stuff FR sent me about the fix at this time
We only have one ram on a slide that is probably about 20' long and the ram is on the light end of the slide maybe three feet from the end.
I can't imagine =anyone= designing something like that. Lousy, lousy engineering. I totally agree with your analysis of the design.
Lyle
Exactly what I thought but the manufacturer and Lippert claim that there are many units out there just like ours that have never had a problem. I'm trying to verify that. BTW, the manufacturer is saying that they may pay at least some of the cost for moving the ram to the center of the slide.
laknox
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
Peg_Leg
jwakeman, could you expand on this washer fix. I did a google search and can't find any info on this.
Yamaha EF3000iSE
retired gadgetman
ThePostman
