I replaced my identical air conditioner a few years ago but with a different make. The replacement you are considering should work fine.
We have an
Atwood 15,000 "Air Command" ducted unit and have been very pleased with it. Our previous unit, a Dometic "Duo Therm" lasted about 13 years before we replaced it with the present one. The Atwood is much quieter than the Dometic it replaced.
Air conditionersYou are correct that the term "ducted" means the air is circulated through "ducts" in the ceiling. These ducts may just be tunnels formed via foam blocks or they may be actual ducts formed with plastic or metal. In the non-ducted the cold air comes directly out of the unit into the trailer.
The reason for the additional cost for a "ducted" unit is because the thermostat and control box for the air conditioner unit are separate from the unit itself. On "Non ducted" units, those are built in to the ceiling panel on the inside of the trailer and also contain the controls (knobs and numbers). On ducted units, like yours and mine, the thermostat (think knobs and numbers) is mounted on a wall someplace, and the control box is mounted up inside the air conditioner. Those two items are usually included in the AC price but the ceiling panel is sold separately from the air conditioner unit itself and is an additional cost.
There is considerable more work installing a ducted unit vs a non ducted hence the additional cost. Not sure about $300 worth though.
Barney
2004 Sunnybrook Titan 30FKS TT
Hensley "Arrow" 1400# hitch (Sold)
Not towing now.
Former tow vehicles were 2016 Ram 2500 CTD, 2002 Ford F250, 7.3 PSD, 1997 Ram 2500 5.9 gas engine
