Rubicon 2900 gas gauge for generator
Poppy___Nana
Can anyone tell me how the gas gauge works for the Dutchmen Rubicon 2900 generator?
I put about 15 gallons of gas into the tank and it still ready empty!
Any hints or suggestions???
Leo & Kathy
Upstate, NY
in the Adirondacks
2013 Rubicon 2900 Toy Hauler
2008 - Ford F250 Super Crew 4x4
4 REPLIES 4
Poppy___Nana
64thunderbolt wrote:
is there a rocker switch beside the gauge? If so just use it. Most have them as the gauge is a draw without the momentary switch.
64thunderbolt - thank you for your response....you had the correct answer! Unfortunately we had left before you posted and just returned and I found your post!
My dealer said it was a faulty switch or bad ground....had it in for warranty work and the service tech informed me of the "switch" - the TH is new to us so we had questions that a manual does not answer!
Thanks again!
Kathy
a/k/a Nana!
Leo & Kathy
Upstate, NY
in the Adirondacks
64thunderbolt
Glen
04 Tail gator XT 34' 5th wheel garage model
200w solar 2 GC2's 800w inv
Truma tankless WH
99 F350 CC DRW 7.3 ais intake, adrenaline hpop, JW valve body,
cooling mist water inj, DP tunes, 4" exh sys
trucool trans cooler added
2011 RZR 900xp
Poppy___Nana
Thank you for the response!
Leo & Kathy
Upstate, NY
in the Adirondacks
Davidlatham2012
I saw this problem before and it had a cut wire on top of gauge at fuel sensor on actual tank itself. you can test gauge by grounding it out to self.
