RV tires on cement
14fan
We are permanent campers and just had a pad poured. What is the best thing to use to put between the tires and Cement? Would those plastic blocks at camping world be strong enough for year round use?
TIA
39 REPLIES 39
MFL
Nomad II
Nomad II
GWolfe wrote:
Maybe this is a question we should start asking on the blow out threads. What surface do you store your trailer on and how long does it sit between uses? I store mine on concrete, last May I had to replace my foreign made cheepo tires because they both had bubbles on the side wall, not even a year old. The only one that was ok was the spare but it got replaced as well. Goodyear Endurance tires are what I replaced them with.
Makes you wonder how fast the delivery guy towed your trailer.
Hope you have good luck with the new GYs! Let us know how they are working for you, after getting some time/miles on them.
Jerry
GWolfe
2005 Sun-Lite Eagle
2011 Silverado
Sam_Spade
mhardin wrote:
There is no reason not to park your tires on concrete.
AND.....if you think putting your tires on TREATED wood is better, you might be fooling yourself. The chemicals used to treat the wood might be worse for the tires than the concrete is. :S
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
Bmach
Yes I do store my battery n concrete, there is nothing wrong in doing that. That is something was true like seventy+ years ago but not now.
mhardin
Birdnst wrote:
Even though some people might not understand why,it has always been said that the chemical make up of concrete can react with the chemical make up of tires, and that wood is the best thing to have under your tires.
snip
Do you store a good battery on concrete?
Why not?
It as been on tire manufacturer websites.
I will not take the time to do your investigating.
First off, it is ok to store today's batteries on concrete. No harm will come to the battery. That is old history. Read More Here
Secondly, tires and batteries are two totally different animals. There is no reason not to park your tires on concrete. Do you park your car on boards in the garage or driveway? Of course you don't because there is no reason to do it.
2013 Ford F-350, 4x4, Crew Cab, Long Box.
2001 Jayco Eagle 266 FBS.
2014 Heartland Elkridge 37 Ultimate.
jffnkrn
Well for us, it is the same as all the previous comments, local, state and federal regulations, and of course my own opinion and practices. But really, we leave ours on the concrete we have on the side of the house which also has our electric, water and sewer connections. We use it once per month, for about a week, and sometimes five or so weeks at a time. longest it sets on the pad without moving is about 6 weeks. So that is me, you be you and we all do our thing. honestly, i am not sure of any damage you will do. but if I were parking it for a couple years or even six months, I would probably level it with mobile home screw jacks and take the tires/wheels off, release some air and stack up on their side. good Luck & Be Save ! ! !
Dennis12
yea, what he said
Dennis Hoppert
Cranemec
Duke-44 wrote:
Who said that?
The Internet. It must be true!
2015 American Coach Tradition 42G
D_E_Bishop
JIMNLIN wrote:
TIA
I mean permanent in that we will not be towing it on a regular basis, but probably will trade it in a few years.
Info posted from tire mfg doesn't cover a tire stored for several year period while still mounted. The tires simple won't last that long while sitting with weight on them. Plus they will go flat .
A google on the subject has much the same info from Tire and Rubber Manufacturers Association and tire makers .....and you don't have to read through off topic comments.
Hopefully you plan to block the trailer up for long term ??
Goodyear does address trailers that will not be moved. They suggest, removing the tires and deflate to, IIRC, 10lbs and laying them flat on a solid surface.
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
2002 Winnebago Adventurer 32V
2009 GMC Canyon
Roadmaster 5000
BrakeBuddy Classic II
Sam_Spade
gbopp wrote:
What happens if the concrete isn't dry? ๐Ÿ™‚
Same thing.
Nothing.
Sam_Spade
Why not?
Yes absolutely.
I don't buy into urban myths/old wives tales......of which that is one.
JIMNLIN
TIA
D.E. Bishop . . . I couldn't agree more !
I think this is one of those areas that you do what you feel is best, and its fine.. If you want to use a barrier, go for it, if not, don't . . .
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
lee_worsdell
all myth,s even batteries
