Sagging floor
Devind33
My 2012 razorback 2650 toy hauler the floor has started to sag in the middle. You can't really see it but you can feel the hump near the front and on the sides. It sinks down about 3/8"-1/2". Should I be concerned or is this normal? I got underneath the trailer and the integrity of the beams all look just fine
23 REPLIES 23
Harold Fairbanks II wrote:
Trade it in as soon as possible.
You have a water leak that has already caused massive damage. The leak is probably tiny, undetectable, impossible to find, and impossible to fix...let alone the massive amount or work it would be to find the damage in the roof, walls, and floor.
Don't tell the dealer about the sag or the leak.
Take the hit now...hopefully it won't be too bad.
Unload it while you still can.
Wow! Just wow........
Unbelievable. 😞 😞
2007 GMC 3500 dually ext. cab 4X4 LBZ Dmax/Allison - 2007 Pacific Coachworks Tango 306RLSS
RV Rebuild Website - Site launched Aug 22, 2021 - www.rv-rebuild.com
arhayes
I'm actually in Elkhart, IN right now as I just had a new ramp door put on my 2014 Grand Design Momentum. We full time in the rig and unload/re-load a Goldwing at each stop which weighs about 1000 lbs. I experienced softness along the center of the door a so much so you could feel the floor flex when walking on it.
These doors are expensive, yet are just foam sandwiched between 2 thin sheets of plywood covered with the non-slip surface inside and the exterior laminate outside.
Alan and Kathleen
2015 Grand Design Momentum 380TH (RVD2)
2014 F350 6.7L Diesel DRW (Stormtrooper)
2012 Honda Goldwing NAVI/ABS (Land Speeder)
Cobra21
Mortimer Brewster wrote:
Y-Guy wrote:
Devind33 kudos for being a person of integrity!!!
X2!
X3 There is enough problems without intentional ones.
Mortimer_Brewst
X2!
If ethics are poor at the top, that behavior is copied down through the organization - Robert Noyce
2018 Chevy Silverado 3500 SRW Duramax
2019 Coachmen Chaparral 298RLS
Devind33
From underneath can you see the floor moving while somebody walks on it?
Nope there is no movement underneath or on top
Y-Guy
Moderator
Moderator
Two Wire Fox Terriers; Sarge & Sully
2007 Winnebago Sightseer 35J
2020 Jeep Gladiator Rubicon
lincster
Moisture readings are normal???
What moisture readings are you taking?
2022 F350 PSD CC 4X4 Dually to pull 2006 LE3905
Lincsters Truck/Trailer
Lincsters Rail
Devind33
I would never be dishonest like that even to a dealer. I did check and the moisture readings were normal.
Harold_Fairbank
