Pull the motor out, probably only two bolts and test it with a 12V source. You'll have to ground the case. One wire is retract and the other is extend. My wife is on the way home right now with a new one for our main slide--$250 at the local RV center. You can get them online too. Replacements come with the gears.
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
