Spartan 1245
ependydad
I'm fairly positive we're going to pull the trigger on a Spartan 1245 by Prime Time Manufacturing. I have a few immediate upgrades in mind (adding a 3rd A/C, slide toppers, and vent covers). But overall, it seems like a very livable unit.
Thoughts? Comments? Witty commentary?
2017 Spartan 1245 by Prime Time
2018 Ram 3500 Crew Cab DRW w/ 4.10 gears and 8' bed
FW Hitch: TrailerSaver TS3
Learn to RV- learn about RVing - Towing Planner Calculators - Family Fulltiming FB page
19 REPLIES 19
I found this on their site -
Spartan Suspension Package - -
“EZ Flex” Rubberized Suspension
Heavy Duty Shock Absorbers
Eight Point Greasable “Wet” Bolts
Long Lasting Brass Bushings
Long Lasting ½” Shackle Plates
7,000 Pound Axles (Most Models)
"EZ Lube" Axle Hubs
16” Aluminum Wheels
8-Lug Wheels
Upgraded G-Rated Radial Tires
Not sure exactly what that means ?? I cannot imagine that it would have 5200# or even 6000# axles with 16" X 8 lug wheels.??
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
ependydad
tinner12002 wrote:
I looked at them online and they appeared to only have 6 lug wheels, 5200 lb or 6000 lb weight rating on the tri-axle models which indicated to me they were already underbuilt in my opinion. Typ of a lot of manufacturers is to just barely use enough to get by.
Do you happen to have a link?
I didn’t crawl underneath but this one is supposed to have 7,000 lbs axles and 8-lug wheels.
tinner12002
2015 Ram 3500/DRW/Aisin/auto/Max tow/4.10s,Cummins, stock Laramie Limited--Silver
Tequila Sunrise 2012 Ultra Classic Limited
2018 Raptor 428SP
ependydad
Lwiddis wrote:
Looks good inside and out. Are the OME tires good?
Sailun S637, so we're good there. Plus it has shocks (presumably Lippert, but hey- some shocks are better than no shocks).
Lwiddis
