stopped up sink.
Lurch59
I have a 2007 Montana Mountaineer fifth wheel. The sink will not drain and the problem lies between the p trap and the gray tank. How do I get this in plugged.
5 REPLIES 5
cpaulsen
A friend of ours had his galley tank plugged up......he took it to the shop and they found it was caked with old dish soap. He was using the cheapest dish soap he could find and they told him to use Dawn dish soap to stop that problem.
cpaulsen
BB_TX
The regular Montanas have a separate galley tank for the kitchen sink if that is the sink you are talking about. The pull handle for my galley tank is just in front of the street side wheels. On some models it is between or behind the wheels. Look around and see if you have a galley tank pull handle.
352
Threaten your wife with a snake. She will then be glad to fix the plumbing.
The manatees of Halls river Homosassa Springs Fl
1985 Chevy Silverado c10. 454 stroker / 495 CI = 675 HP. 650lb of torque. Turb0 400 tranny. 3000 stall converter. Aluminum heads. 3 inch exhaust flowmasters. 2 inch headers. Heat and air. Tubed.
Old-Biscuit
Bucket under 'P' trap.....remove it and clean it out
With it out....run snake down thru drain line into grey tank
Kountryguy
Try a snake.
