Suggestions for a shorter 5’ver…
John___Christin
Looking at 5th wheels. We are a family of 4 that doesn’t need a ton of space. Mom, dad and 2 teen boys. We are all well experienced campers. We’ve owned a few 5th wheels in the past. I’ve been looking around for a 5th wheel that fits our needs but just want to see if anyone has any suggestions. Here’s our criteria below in no particular order. Thanks
Around 30’ or less… we’re limited to this size because of the amount room in our driveway. We have a lot of vehicles.
Bunks… we just like a bunk model for the kids.
Higher end brand…. Don’t mind paying a few $$ for something of better quality.
Four season if possible…
Weight not a factor. We’re going to buy our TV after the RV.
For Sale:Twin Ultra Power HD 6 volt batteries in excellent condition. Very similar to Trojan T-105's. Located in MA. Email Brazenheadbeer@gmail.com
26 REPLIES 26
philh
Artic fox 27-5L
2012Coleman
You didn't ask for 1/2 ton tow-able, but that's where you will find what you are looking for. Here are some great examples: Brochure hitch weights are for entertainment purposes only...
Reflection 150 Series 268BH - single wide rear bunks
UVW: 7,893 lbs | GVWR: 9,995 lbs | Hitch Weight: 1,268 lbs | Length: 31'11"
Reflection 150 Series 278BH - double wide rear bunks
UVW: 8,345 lbs | GVWR: 10,195 lbs | Hitch Weight: 1,321 lbs | Length: 32'11"
Reflection 150 Series 280RS - rear tri-fold soafa, but 30" 11" long
UVW: 8,566 lbs | GVWR: 10,995 lbs | Hitch Weight: 1,384 lbs | Length: 30'11"
https://www.granddesignrv.com/showroom/2021/fifth-wheel/reflection-150-series/floorplans
2018 RAM 3500 Big Horn CTD
Thermoguy
Saw this in a CG in Northern NY, Obviously older, and not sure of the exact length, but it is the smallest 5'er I've ever seen.
Now that looks like a 1/2 ton towable 5th wheel - good find.
Thermoguy
Mine is 32' with bunk house - older, not high end. But fits most of the boxes.
If I was doing it over again, I would go toy hauler and go with the garage in the back as the bunk house. Not at that length, but under 40' no problem.
There are some great mid bunk, but not for large kids, only small kids.
I really like the Sierra with a rear queen bunk house. That is a new design, not a small unit, but very nice setup.
MFL
Nomad II
Nomad II
^ If not really wanting high end, or true 4-season, there are lots of these light wt, so called, 1/2 ton towable FWs out there. Yes even this 31'11" 150 model.
If it works for you, that is good find!
Jerry
John___Christin
MFL wrote:
OP...it just is not going to fit in the 30' or less!
Bunks-not likely
higher end-less than 30'...nope
4-season...maybe so called, not truly
You need to get into a mid-size, closer to 35', to check most boxes.
Jerry
Found this at 31’
https://www.granddesignrv.com/showroom/2021/fifth-wheel/reflection-150-series/floorplans/268bh
goducks10
You could find that all day long in a TT. Less $$$ too. I get the 5er vs TT thing. BTDT. With a good WDH towing will be fine.
SDcampowneroper
2011 carriage 32 fws is the closest I can think of that comes near your criteria. You could build bunks in the rear. Theres a couple for sale on rvtrader.com
MFL
Nomad II
Nomad II
Bunks-not likely
Jerry
bukhrn
Not exactly sure why they listed #5 and 6 as they are far from small, https://trailandsummit.com/what-is-the-smallest-5th-wheel/
2007 Forester 2941DS
2014 Ford Focus
Zamboni, Long Haired Mini Dachshund
StirCrazy
Moderator
Moderator
I was the opposit with two tean girls, I would imagin that with tean boys they love to be able to get away and sleep in a tent, at least I did when I was a tean. if this is the case, just show as if its only the two of you normaly and the 4 in an emergency. that way your not stuck with more than you need when they leave the nest. I ended up getting a monster because the girls likes to sleep inside and bring friends, but we bought a modle that had a bunk room that we can just leave the slide in and door closed untill the grandson is ready for camping.
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumber Queen WS100
bukhrn
2014 Ford Focus
