โFeb-20-2018 04:59 PM
โFeb-22-2018 11:57 AM
โFeb-22-2018 11:13 AM
โFeb-22-2018 08:07 AM
โFeb-22-2018 06:27 AM
โFeb-22-2018 03:36 AM
taken wrote:
Steve, have you checked your Equalizers to see if your shackles are flipped?
โFeb-21-2018 05:44 PM
โFeb-21-2018 05:34 PM
โFeb-21-2018 12:24 PM
tmilicia wrote:
Yes, you are wrong. When the equa-flex shackles flip, the whole rear axle will move forward, significantly reducing the spacing between the middle and rear axle & tires. Been there, done that, got the t-shirt...
โFeb-21-2018 10:52 AM
smsage999 wrote:But you did say you bought the trailer used, and I was wondering if the individual you purchased it from had done some suspension work too. Perhaps badly.joebedford wrote:fj12ryder wrote:What I don't know is if OP measured the distance between axles or axle hangers. If the wrong equalizer was put in, that would affect the distance between axles even if the hangers are the right spacing.joebedford wrote:They should be if the distance between axles is the same, but this trailer has different distances between the 3 axles. Dexter shows two different length equalizers, and which one you need is determined by the axle spacing.
Shouldn't the equalizers be the same dimension eye-to-eye?
Also, I've had a spring shop put the wrong spring in my rig. Maybe when he got his springs replaced, they put in two different sizes.
I did the spring change out and I did not change equalizers, or shackles. Only the springs, bolts and U-Bolts. I did not measure hanger to hanger, but I will tonight. My measurements are axle center to axle center. The equalizers were measured center eye to center eye.
According to the spec sheet from Dexter, for a triple axle, the spacing from axle center to axle center should be 35 inches.
โFeb-21-2018 10:50 AM
โFeb-21-2018 10:00 AM
โFeb-21-2018 09:46 AM
fj12ryder wrote:
"The axle spacing from front to middle axle is 34 inches on center, with the equalizer measuring 7 inches eye-to-eye.
The axle spacing from the middle axle to the rear is only 31 inches on center, with the equalizer only measuring 5-3/4 inches eye-to-eye."
Am I wrong or does this specify that the axle spacing is different when measuring from front to middle, and from middle to rear. This can't be explained by axle hangers flipping or improperly installed equalizers.
It will be interesting to see what Forrest River says about this situation.
โFeb-21-2018 09:18 AM
โFeb-21-2018 09:08 AM
โFeb-21-2018 08:57 AM
