Hello everyone,
Looking for input and advice here:
Current set up:
2018 GMC with factory inbed puck system
Pullrite 20k(non-slider) hitch with the adaptor bracket to utilize the factory puck system
Trail Air pin-box on the trailer
My over height of the trailer is 13'5.5"
The hitch is adjusted as low as it can go and the pin box is adjusted as high as it can go. I have nowhere else to adjust to lower my overall height.
I am curious to those of you that have used, or are currently using the factory puck system for your 5th wheel. I am looking for a hitch that does not require the adaptor bracket(this will lower the trailer about 3").
What do you use and how do you like it?
I really like my Pullrite hitch, but the recent addition of the trail air pin box has increased the overall height of my trailer. It is noticeably "nose-up" with the current set up.
Thanks for the information,
Ryan
2018 GMC 3500 Denali Crew Cab Dually Duramax/Allison ๐
2015 Cedar Creek Silverback 35QB4
Ryan, Marsha, Alyssa and Emily
"Opportunity is missed by most people because it is dressed in overalls and looks like work" ~ Thomas Edison
