The macerator pump system
blkdodge
Has anyone used the portable system? How do you like it and what size
Hose do you use? On my property that I’m building the sewer is approximately 100 feet from 5wheel. I really don’t want to use a tote because once I finish the house I won’t have a need for a tote. I could always use the pump even for visitors.
Thanks David
2012 Dodge 3500 DRW/2012 Heartland Landmark San Antonio.
11 REPLIES 11
bpounds
Since someone brought up the Sewer Solution, I will comment even though it might be off-topic.
I have the SS, and I like it a lot. But I would not try to push waste 100' with it. They say it will work, and it might if it were all downhill, but I don't believe it would be an effective way to go even if perfectly level, and definitely not over any rise.
It breaks up solid waste just fine. That's not an issue.
2006 F250 Diesel
2011 Keystone Cougar 278RKSWE Fiver
Allworth
We lived in the fiver for 4 months while our son and his family were having a house built and lived in our house. The trailer is in the back yard and had 50Amps and water.
I used a FloJet and 50' of 3/4" garden hose to get to a cleanout at the kitchen drain (to septic system).
The Flojet worked perfectly AFTER we sorted out a manufacturing problem. On the first one, purchased from Amazon based on delivered price, the motor froze up the third time I tried to use it. I called customer service and then e-mailed them a picture of the I.D. plate on the motor and they air shipped a replacement (entire unit) the same day under warranty.
Emptied the black tank every three days after that without a problem. I did run the grey tank into a dry well by the back fence and didn't bother pumping it, but I could have.
Formerly posting as "littleblackdog"
Martha, Allen, & Blackjack
2006 Chevy 3500 D/A LB SRW, RVND 7710
Previously: 2008 Titanium 30E35SA. Currently no trailer due to age & mobility problems. Very sad!
"Real Jeeps have round headlights"
MNRon
Had a sewer solution 15yrs ago. Thought it was good until I used the regular 3” sewer hose...the std Rhino hose, that woks MUCH better and doesn’t waste all the water a sewer solution does.
I also used a FloJet at last home where I regularly dumped to our septic, about 100’ fairly level. Used a 1” hose for this (custom ordered). This worked very well, but not as nice as the Rhino hose in our dedicated dump in our current house.
Ron & Pat
2022 F350 Lariat CCSB SRW Diesel
2019 VanLeigh Vilano 320 GK
theoldwizard1
jdb7566 wrote:
I made one by modifying a garbage disposal unit. The opening is the same as your standard RV sewer hose.
I saw that on YouTube ! I worked amazingly well !! I would not try to pump uphill more than a couple of feet.
want-a-be
johndeerefarmer wrote:
want-a-be wrote:
Save your money and take a look at the sewer solution. We have one, with water pressure I can push waste a long way!! Good Luck
Sewer Solution looks like a waste of money. A stream of water isn't going to break up solid waste like the blade on a macerator.
I have a macerator and it works fine. My daddy said you usually get what you pay for!
Did your daddy ever tell you don’t judge a book by it cover??
johndeerefarmer
2020 Ford 350 6.7 PSD & 2017 F150 3.5 EB max tow
GD Reflection 29rs
rv2go
I use this macerator-pump that I made. I pump 75' thru a 3/4" hose. I do not have to put up with the 12v model over heating and having to wait for it to cool off so it will start again.
Winnebago Journey
TN Lic. RV 2 GO
Jeep Cherokee 4x4
I'm here #4335
Blog
want-a-be
jdb7566
dieselbobcat
Have been using a FloJet 3" bayonet style macerator for 5 seasons now... replaced the impeller 4th season as preventive maintenance. Couldn't be happier. We haven't carried a slinky since we got it. Use a 25' and 50' standard heavy duty black rubber garden hose. Have pumped 125' and uphill with no issues... It does require a dedicated (10ga) power supply direct to battery.
2014 Rockwood Ultralight 8312SS Diamond Edition
2016 F350 Super Duty Crew Cab Lariat Ultimate 4X4 6.2L
ugeesta
We have the factory maceator pump on our Talon and love it. No more trying to get real close to the dump pipe. The nozzle fits right into the pipe and is already attached so no messing with dirty, wet hoses after the tanks are drained. One thing to watch out for is when the tanks are empty, be sure to shake out the hose to the drain before discunnecting cause there will be left over water in the hose.
What has me slightly concerned is how to drain the maceator system for winterising. Since there is a good 12 feet of hose attached to the bottom of my trailer, the hose won’t fully drain. So, it looks like I’ll have to buy 5 gallons of antifreeze this fall to make sure I get all the water out of the pump and hose.
The hose on ours is a 2” hose and that works just fine for dumping.
2018 GMC Seirra 3500 Denali SRW
2018 Jayco Talon 313t
2019 Polaris XP1000 Trail and Rocks edition
2016 Yamaha Grizzly EPS
1 wife & 5 cats
