Tire Air Pressure Sourcs
ken_burke
All. . . . I use 110 psi for my 5th wheel tires. (GY load range G (614??) 3000 #s each tire).
How do you pressure your tires to 110 Psi?? Can they or I do that at a truck stop? I have a good press pump 1200 miles away.
thanks ken burke
2011 Ford F-350 6.7 diesel, Crew Cab, LB, SRW, 4X4, White
Cedar Creek 34SB, 37 feet 5th wheel, Reese 20K Hitch
"So many questions, so little time."
7 REPLIES 7
ependydad
I preferred having a 12v solution because I didn't have a generator at the time for 120v power on the side of the road.
The Viair fit the bill very nicely. Runs my tires up to 125psi quickly.
http://learntorv.com/product-review-viair-450p-12v-air-compressor/
But, reading your last post- I might be a little late. ๐Ÿ™‚
2017 Spartan 1245 by Prime Time
2018 Ram 3500 Crew Cab DRW w/ 4.10 gears and 8' bed
FW Hitch: TrailerSaver TS3
Learn to RV- learn about RVing - Towing Planner Calculators - Family Fulltiming FB page
ken_burke
Alll. . .
thanks for the comments . . .I am on my way to Lowes. I could use a second air compressor.
See you on Rt 10.
ken burke
Cummins12V98
thanks ken burke
Most RV parks have an air compressor that can be used. Inflate when your tires are COLD!!!
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
memtb
We just got one of these. Itโ€™s small, relatively flat....stores easily. Has mixed, but pretty good reviews. Havenโ€™t used it yet, but will try soon. Take a look at it, it may be your answer!
Todd & Marianne
Miniature Schnauzer's - Sundai, Nellie & Maggie Mae
2007 Dodge Ram 3500, 6.7 Cummins, 6 speed manual, 3.73 ratio, 4x4
2004 Teton Grand Freedom, 39'
2007 Bigfoot 30MH26Sl
SidecarFlip
In as much as most truck tires inflate to 105-110 psi, any truck stop air hose will work fine...
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
Slownsy
Yes you can at service center if they have a compressor, yours should live in truck.
Frank.
Frank
2012 F250 XLT
4x4 Super Cab
8' Tray 6.2lt, 3.7 Diff.
donn0128
150PSI pancake compressor. Lowes sells Porter Cable which is good for around a hundred dollars.
