Tire choice
blkdodge
I have GY614 that are 5 years old.. Which would you choose?
Goodyear
Saliun
Sampson
Gladiator
Goodyear's are roughly $1,700.00. All others between $1,000.00-1,200.00
2012 Dodge 3500 DRW/2012 Heartland Landmark San Antonio.
43 REPLIES 43
ol_Bombero-JC
Cummins12V98 wrote:
otrfun wrote:
Cummins12V98 wrote:
fj12ryder wrote:
^^^^^^Not so much a toss up when you factor in the cost. ๐Ÿ™‚
Cost is NOT everything to some.:)
True.
And, for others, spending significantly more for name-brand items can sometimes feel like conspicious consumption . . . crossing the line from practicality and substance to "bling".
5 sets of US Made GY's from "E" to "G" to "H" not even a flat. I will stick to what works well for me. MANY thousands of miles.
Nice to have choices, nice to spend my money frivolously.
And frivolous posts, LOL!
R U kin of "no longer here" Fast Eagle?..:W
He liked to buy lots of tires also.
skijlw
I have had 3 blowouts and they all are expensive repairs and sometimes a dangerous situation. Goodyear G614 would be first choice and Maxxis next. Don't skimp on tires. I like the Goodyear but I am impressed with the Maxxis. The tire is really heavy duty.
Cummins12V98
otrfun wrote:
True.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
momentum_rv
Good choice, betting you'll do much better than 4 years.
2015 Grand Design Momentum 385TH
2015 Ford F-350 DRW 4x4 Lariat
blkdodge
Well., I chose the Sailuns S637, mounted,balanced and certificates all for $920.00. I figure if I get 4 years out of them I will be happy.
otrfun
True.
Nodaker
I put Sailun S637's on my 2015 5er before leaving for Alaska. Just the difference in heft between the original cheap tires and the Sailuns convinced me the change was good. Currently near Denali with no tire worries!
Nodaker
2017 Newmar Bay Star 3113
2011 Chev Colorado dinghy
2oldman
Me Again wrote:
You have a large heavy landmark trailer????
Not a landmark, but it is heavy.
I have about 12k on the tires, that's 3k/tire, which is (if I remember correctly) about the max load on load range E tires.
fj12ryder
Very true. But sometimes you can get as good a product at a lower price.
The higher price of the GY seems to factor in the possibility of covering damage. I kind of look at that as an "extended warranty" and if you feel the product is good enough you may forego the extended warranty and spend less money.
Some products are proving their reliability and perhaps don't need the extended warranty as badly as others.
Howard and Peggy
"Don't Panic"
larry_barnhart
being as safe as possible is what is important to us but stuff happens.
chevman
chevman
2019 rockwood 34 ft fifth wheel sold
2005 3500 2wd duramax CC dually
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
Cummins12V98
Cummins12V98
Terryallan wrote:
MARKW8 wrote:
Terryallan wrote:
Can you get MAXXIS? Best choice.
At any rate. I would stay away from GY
Why should I have a concern with a Goodyear G rated tire? The 614 is an LT tire.
Mark
Nope just ant Goodyear. Way over rated, over priced and just bad. There were all I use to buy, until I figured it out, they don't last.
If you are tailing their "G" or "H" tires as "just bad" please explain. Since early 07 they have a stellar reputation.
Cummins12V98
He is talking "G" rated tires, NOT will-pop class.
Cummins12V98
Goodyear
Saliun
Sampson
Gladiator
Have the GY's given you good service? That should answer your question.
Personally I would have no issue running either the GY "G" or "H" tires for 7 years. Do a little shopping, your $1,700 figure is on the high side. You should be able to get $300 for your tires on Craig's list.
Also remember GY is the only one that WILL pay for damages.
