Tire Clearance
klr650goldwing
Our 5er currently has 3" of clearance between the top of the tires and the trailer. If larger tires were installed, and that clearance were reduced to 2.5" would those tires rub on the trailer?
2014 Grand Design Solitude 369RL
2017 F350 6.7 DRW CC LB 4X4
2012 Mercedes E550
2010 Honda Civic
2009 Saab 93 Aero Convertible
2004 Honda Goldwing GL1800
2004 Kawasaki KLR650
1966 Honda 305 Dream
4 REPLIES 4
N-Trouble
Jack one axle up and see how much clearance you have right now. There lies your answer...
2015 Attitude 28SAG w/slide
2012 GMC 2500HD SLT Duramax
B&W Turnover w/Andersen Ultimate 5er hitch
ScottG
can you drive the rig off a curb or up onto block of wood? That would indicate how high up the wheel will travel.
JIMNLIN
much depends on the axle capacity. I've found springs on 5200/6000/7000/8000
/10k leaf spring trailer axles have very little compression/rebound while going down the road.
However hit one of those RR track on secondary state highways that can bottom out the suspension. I've had no problems with 2 1/2" at the top.
Lots of trailer owners may see tire marks at the top of the wheel well. Most of the time that comes from the suspension walking through a ditch.
Most of my other non rv trailers do it but it doesn't hurt anything. Its just a short kiss at 2 mph.
CALandLIN
The best answer for that may come from the axle manufacturer. The ones I've seen information on have a 3" - 3.5" minimum range.
It's also a question a savvy tire installer would figure-out before installing tires taller than the Original tires.
Click Here!
