Tire wear outside rear curb side
KNSMCCL
Had this problem in January, Took it to Camping World of Chicago. They replaced the shackles and bushings aligned the axles. I replace all 4 tires and rims had them balanced. Drove to Florida after it was in the shop a month.Looked OK Drove to Nebraska almost 3700 miles for the trip and i'm back to square 1. I have a warranty but I would like to get a little more insite on what might be wrong. Trailer is not over loaded. Trying to find a Dealer to make the proper repairs in this pandemic time.
2000 Dodge 2500 4X4
1986 Fleetwood Terry Taurus 245 FW
Westminster, CO
You never no what's around the next corner. [unknown]
12 REPLIES 12
allen8106
Take it to a trailer shop and have them align it. RV dealers have no clue on alignments.
2010 Eagle Super Lite 315RLDS
2018 GMC Sierra 3500HD 6.6L Duramax
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 68
Super_Dave
Take center of axle to center of axle measurements on both sides. I had a similar problem and the shop that I took it to said the rear axle had slipped a little. The distance between axle centers on the curbside was about 1/2"" different than the street side.
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 21' North River Seahawk
laknox
Could also be a bent spindle, especially on the curb side.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
JIMNLIN
One tire wearing the outside of the tread ??
More than one thing to suspect but one big one on a trailer is the the tires tread delam issues. Most of the time a tire center of the tread is higher but I've had delam issue on the outside and on the inside of the tread.
How do the bearing look on that wheel ??
allen8106
Don't take it to an RV dealer, they don't know jack squat about alignments. take it to an axle shop and get it aligned.
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 68
RAS43
Your profile shows a Westminster CO address. If that is current contact Diversified Body & Paint Shop in Denver, 303-289-4797. They are a heavy vehicle & RV repair shop. They have done an alignment and repairs on my 5th wheel and I am very satisfied with the work.
memtb
It sounds as though you have a toe-in or camber issue....maybe both. Did they “bend” the axles to give the proper toe-in and camber measurements? memtb
Todd & Marianne
Miniature Schnauzer's - Sundai, Nellie & Maggie Mae
2007 Dodge Ram 3500, 6.7 Cummins, 6 speed manual, 3.73 ratio, 4x4
2004 Teton Grand Freedom, 39'
2007 Bigfoot 30MH26Sl
Cummins12V98
First mistake "Took it to Camping World of Chicago" unless that is who you HAD to take it to.
Find a good independent Trailer repair/fabrication shop.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
fj12ryder
Do you have to take it back to the Camping World that did the work to have the warranty apply? Without pictures or seeing the tire, it's very hard to tell what the issue could be. You don't say whether it's one tire, two tires, or more. Triple axle, double axle?
Howard and Peggy
"Don't Panic"
big_bird_2
All RV dealers are open if they want to be. You did not described how the tire is wearing. It is not unusual for the front curb side to wear uneven as the inside tire does not turn, it slides. It may be your rear is sliding on some turns as well.
Do you have China bombers or more expensive American or Europian tires?
Camping World should be open. I have family that manages a large CW store in Texas and they and open and overflowing with business. It may be state to state on who is open.
Big Bird 2
KNSMCCL
Yep its a going to be a real problem to get this done. but hopefully i can find a dealer to get this done. So when we can all start traveling again it will be ready for the road. Happy trails to all.
2000 Dodge 2500 4X4
Westminster, CO
Lwiddis
“Trying to find a Dealer to make the proper repairs in this pandemic time.”
Good luck. Can’t go anywhere for at least another month regardless.
