Tires
84bob
I was on a trip and had two blowouts on 3 year old BF's. Replaced them all with Geostar ST235/85-16/14 G574.That was what was avaible in this town.Are they any good.
2010 Heartland Bighorn 3055RL
2006 Dodge 3500 SRW CUMMINS
9 REPLIES 9
topjimmy
NO they are not garbage my Geostar LT G rated G574's, They are not ST tires have been great and I know 4 people with them as well they are sold at ALL LES Schwab tire dealers here on the west coast with a full warranty they are a Great alternative to expensive Goodyear G614's DO NOT HEASITATE with these tires they perform great Don't listen to people that have never owned them ,I am a fulltimer and have been all over the West coast in the last 2 years with them on Crappy roads,100+ degree weather on my 15K +LB 2015 40 ft Montana 5th wheel..Very happy with them
2015 Montana 3735MK Legacy,2007 3500HD GMC Dually LBZ Duramax/Allison ,Pacbrake,Firestone Airbags Bullydog Tuner
ronniedean1234
I have had the on our 5ver for 3 years and are wearing great, have about 15k on them now, Les Schwab tire here in the North West sells them at all locations...14ply all steel radial and as mentioned above it takes a 110 psi rim
17 Voltage 3970
1999 Freightliner Western Hauler CC/300 Cat/Chipped
2001 Ford F350 CC DRW/ 4x4/ 6 Speed/Chipped
dbbls
They should be OK if your rims are rated at 110 PSI. I suspect they are but it is stamped on the back side of the rim.
2011 F-350 CC Lariat 4X4 Dually Diesel
2012 Big Country 3450TS 5th Wheel
Me_Again
http://geostartrucktire.com/tires/steerhighway/geostar-g574?tab=specs
This is an all steel ply tire similar to the Sailun tire. At 31.7 inches it is a inch larger than the standard ST235/80R16E or the GY G614, so watch distance between tires, you will loose 1". Chris
n7bsn
I'd never heard of them, and no major chain sells them (a telling point)
Consumer Reports lists them as "no bargain" link
I ended up with another "no-name" tire when I had to replace a tire in a small town. It's now the "spare" that I hope to never use.
I consider an early replacement.
2008 F350SD V10 with an 2012 Arctic Fox 29-5E
When someone tells you to buy the same rig they own, listen, they might be right. When they tell you to buy a different rig then they own, really pay attention, they probably know something you don't.
2oldman
other posters have used them i have no idea how to find it
WyoTraveler
Triker33
Kind of late now to find out if they are good or not isn't it?
Can your rims take the PSI those tires require?
Can you keep below the 65 MPH rating of the tires?
65 MPH top speed for only short time not a consent 65 MPG or more.
Larry Full Time Since 99
1999 34Q Discovery DP ISB 275HP 6 Speed Allison
VMSpc | Pressure Pro
14 Lincoln MKS EcoBoost Toad
Click here to see where I am
donn0128
Not particularly. ST tires in general are garbage when you compare them to similar sized LT tires. Speed rating is only one part of the equasion, but a big part of the high failure rate.
