tires
mikemgb77
dose any body have any info. on G614 tire or Gladiator tire
21 REPLIES 21
ol_Bombero-JC
NEVER any tire threads on here........:R..:R
......use the search feature -current and archives- for at least a couple of hours of reading...:W
Cummins12V98
YnotTurbo wrote:
My Goodyear G614's cost 300 a piece. They are expensive,,,but very reliable tires.
Good call you won't regret the investment. I am so confident in my GY "H" tires I am not adding TPMS.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
YnotTurbo
Navy Chief (Ret.) Still working. 2019 Ford F350 Lariat, 4:10 Geared and 935 lbs. of Grunt..., 2011 Mobile Suites Lexington
JIMNLIN
As I said above I would rather stick with what Gladiator web says.
However having a good G rated poly tire makes for more options for those that are looking for a low cost quality tire for rv trailers that sits a lot.
Me_Again
JIMNLIN wrote:
Like Discount Tire or the Tirerack and other tire dealer add specs that sometimes are different than the tire mfg specs I would go to the tire mfg websites and get the info straight from them. http://www.gladiatortires.com/benefits.php.
I sent this question to Simple tire.
Are there still two Gladiator tires? Chris
All Steel
http://simpletire.com/gladiator-235-85r16-1143273865-tires$179.99
Poly Carcass
http://simpletire.com/gladiator-qr35-tr-trailer-service-tires$141.97
Their Answer:
Yes there are
Support Team
info@simpletire.com
http://www.simpletire.com
(888) 410-0604
Me_Again
JIMNLIN, if you look at the part number 1933273865 on the link you provided, that matches up to the poly carcass tire on Simple Tire site.
The all steel one carries Part #: 1143273865 on Simple Tire. Given that Simple tire is the major importer of these and Sailun tires I would go with what they have on their site.
Chris
dbbls
First, do you need G rated tires? You didn't mention how heavy your 5er is so you may be doing overkill. An E rated LT tire may be enough. If I needed G rated, I would go with Sailun. IMO just as good as G614 and about half the price. Also check your rims. G rated tires require 110 PSI.
2011 F-350 CC Lariat 4X4 Dually Diesel
2012 Big Country 3450TS 5th Wheel
JIMNLIN
Just make sure your get the (AS) all steel "QR35-TR(AS) Trailer", as they also have a fabric QR35-TR Gladiator. Chris
Actually Gladiator websites shows just one Q35 which with the steel ply carcass tire ; (quote)
" It offers the QR35-TRยฎ, a Premium 5-rib Trailer Service tire that can also be used in all positions,"
Then lists the one 235/85-16 G along with 22.5" and 24.5" tires sizes.
larry_barnhart
1ofmany wrote:
allimax wrote:
The G614, though expensive, are the way to go IMO.
We are running G614s without any issues, so agree with allimax.
same here.
chevman
chevman
2019 rockwood 34 ft fifth wheel sold
2005 3500 2wd duramax CC dually
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
1ofmany
Me_Again
All Steel
http://simpletire.com/gladiator-235-85r16-1143273865-tires $179.99
Poly Carcass
http://simpletire.com/gladiator-qr35-tr-trailer-service-tires $141.97
MARKW8
I am very happy with my G614s. 12,300#s on the axles, plus 5k miles and doing fine.
Mark
JIMNLIN
16" load G Tires like the Gladiator Q35 or the Sailun S637 or the Hercules H-901 are more of a commercial grade tire that are more popular with regional haulers (commerce) on their trailers than the G614.
Main reasons are those folks may run 75k+ miles a year so dollars saved when tire costs are factored into the business.
I have six Sailun S637 on a 36' tri axle GN stock trailer with 7k axles. Great tire for the bucks.
allimax
2010 Montana 3455SA
Mor/Ride kingpin, wet bolts, Progressive Ind. HW-50C EMS,TST 507RV TPMS, GY G614's
'07.5 Silverado D/A LMM 3500HD
Extended Cab DRW 4x4 LTZ
Bilstein, Reese R20, Banks Economind tuner, Speedbrake, RamAir, Monster exhaust
