โAug-09-2018 08:19 PM
โAug-10-2018 09:22 PM
Butch50 wrote:
I don't believe that you can just throw 3500 springs on it as the 2500 has rear coils not leaf springs
โAug-10-2018 08:34 PM
Wild Card wrote:
if you do get stuck with it throw some airbags on the 2500. If its leaf sprung swap them for 3500 springs. Given that it has the same rear end as a 1ton SRW truck, if it has the smaller varient rear no go as that axel is your limiting factor. If its a coil sprung rear forget about the above. $1000k fix vs $60,000 fix...the choice is yours
Given rear leafs and same rear as a 1ton the only difference between 2500 and 3500 is rear leafs, a badge that says 3500 and a stupid sticker on the door mandated by the Guberment.
Prove me wrong...
Weight Police remember real trucks are built not bought every day by builders and fabricators, air ride suspension, stretched frames you name it...everyday.
โAug-10-2018 05:47 PM
โAug-10-2018 11:02 AM
Bob Bo wrote:
@Old_Buscuit
"3500SRW with that 7000# RAWR will be a match for that 16,750# GVWR 5th wheel"
"Match" as in it will work, or it will be tough?
Thanks for the help
โAug-10-2018 09:45 AM
Prove me wrong...
But the silly little yellow sticker says.... ?? ?? ??
โAug-10-2018 09:19 AM
Prove me wrong...
โAug-10-2018 08:51 AM
โAug-10-2018 08:43 AM
โAug-10-2018 08:37 AM
eHoefler wrote:
Usually there is a cooling off period, normaly 3 days, to rescind the contract. If they don't have any money from you, no court will force you to purchase. Believe it or not, you are in charge at this point.
โAug-10-2018 08:35 AM
Bob Bo wrote:
I'm hoping at this point I can work out a back out deal. I'll hopefully be shopping for a smaller RV soon.
Thanks for the help,
Bob
โAug-10-2018 08:32 AM
Bob Bo wrote:
I've got the potential to jump up to a 3500 SRW.
2018 Ram 3500
6.7L Diesel
Automatic
4x4
Short Bed
Crew Cab
GVRW: 11,700
Payload: 3,930
GCRW: 25,300
Max TWR: 17,060
GAWR Front: 6,000
GAWR Rear: 7,000
Thoughts?
โAug-10-2018 08:25 AM
Bob Bo wrote:
Hey all,
We just purchased a Montana 3810MS and I'm trying to make sure I've got enough truck to pull this thing. Anyone that can give me some advice, I appreciate it.
Tow Vehicle:
2018 Ram 2500
6.7L Diesel
Automatic
4x4
Long Bed
Crew Cab
Montana 3810MS
Dry Weight: 13385lbs
Carry Cap: 3365
Hitch Weight: 2745lbs
Dealership seems to think I'll be absolutely fine, but I'd like to get the thoughts from experienced folks. Again, any help is appreciated. Hopefully we haven't gotten ahead of ourselves.
Thanks,
Bob
โAug-10-2018 07:14 AM
โAug-10-2018 06:41 AM
Halmfamily wrote:
We looked at Grand Design toyhauler last weekend, pulled in with our 08 Dually. First thing out of the salesman mouth is we can pull anything on his lot. How so, I ask. Your truck is a dually with a diesel he said more than capable. I pointed out the pin weight of the GD as well as my aux fuel tank and the fact my towing rating is 15500lbs, no way. Maybe a newer dually. Know what you truck is capable of, the dealer doesn't care.
โAug-10-2018 04:39 AM
