Feb-07-2014 05:43 AM
Feb-11-2014 08:27 AM
Me Again wrote:afishinado wrote:
Thanks guys for the heads up... Somewhere I read the 6.4 was best they made of the International engines, and it was tone one to get... Just looked deeper into the 6.4 Ford.. Can't justify a 2011 or newer truck any more than I can justify $80k for my 1st trailer...
Looks like it'll be a Duramax or a Cummins
Go find a 2006 or 2007 Chassic GM D/A with the LBZ engine and 6 speed Allison. Best there was!
Chris
Feb-11-2014 05:00 AM
Feb-11-2014 02:47 AM
Feb-11-2014 02:36 AM
Feb-11-2014 01:21 AM
Feb-10-2014 10:30 AM
psford wrote:Me Again wrote:afishinado wrote:
Trying to do my due diligence on the tow vehicle selection. Looking at towing 5th wheel toy hauler... The pin weight is high on them when empty, but with two Harleys on the tail I think it'll be well within SRW territory which is what I really want. Now I need to investigate this 19.5" wheel thing you guys are talking about.
Edit: You guys mentioned 'late model' trucks being better at this than they were.. Would 08-10 be considered late enough model? Looking for one in that year range as I like the GM & Ford diesels they used at that time.
You probably do not want a 08-09 Ford 6.4 diesel. The 2010 was the first year of the 6.7. To me it would be anyone after the 7.3 however!
Chris
You may want to check your facts, the 6.7 Power Stroke was first introduced in model year 2011, 2010 was still the 6.4 2008-2010
Feb-10-2014 08:28 AM
Chris
Feb-10-2014 08:13 AM
NC Hauler wrote:
BUT...what happens if the connection between the truck and 5er comes unplugged or malfunctions?? I agree with both of you about disk brakes on the RV, BUT, I'm talking about having enough truck towing a very heavy 5er and one loses the braking ability of the 5er...it doesn't matter what kind of brakes you have on the 5er "IF" you lose the ability to make the brakes on the 5er work....THAT's when the EB, the T/H mode using the tranny to help slow one down, THEN the brakes that are on the TV itself...That's what I was getting at. It happened to me, bad thing, it was on a 7% grade downhill.....
My truck and the dinky electric brakes work like a charm, have never had an issue, they work flawlessly........until the cable from the 5er to the truck became disconnected...now, no brakes on the 5er...doesn't matter if they're disk brakes or not....if no connection, your truck now has to stop all this weight..THAT is what I was talking about.....
Agree, one has to have enough truck to stop all that weight, just in case something happens to someone while towing.....like it did to me.
Feb-10-2014 08:09 AM
kakampers wrote:Cummins12V98 wrote:j2catfish wrote:
One thing that always causes me pause is this idea that the truck has to be big enough to stop the 5er. That would be a good built-in safety factor but shouldn't the trailer brakes be good enough to stop the trailer? I know that might be a challenge for the electrical brakes commonly used but more and more rigs are using electric over hydraulic disk brakes and really have a greater stopping ability. Not to start the war over, but what do you think?
Catfish
My truck and DRV stop seamlessly because of the MaxBrake and the disk brakes on the RV. Sounds like a chichi but there is no delay you just feel the truck stop like driving solo. Before this combo I never thought that was possible.
What is important is having enough truck to handle the length and weight of what you are hauling in any conditions.
Although we seldom agree...I DO agree wholeheartedly on this subject!!
Our 2011 Chevy with tow/haul and exhaust brake and Landmark WITH disc brakes feels the same way...and we never dreamed it was possible to stop so seemlessly! Having "enough" truck for the load AND great trailer brakes makes all the difference!!
Feb-10-2014 05:39 AM
afishinado wrote:The weight in the back won't change the pin weight as much as you think it might. When I load our bikes, which weigh about 1200 lbs., it only changes the pin weight 40 lbs. So it just depends on the geometry of your particular toyhauler.
Feb-10-2014 05:11 AM
Feb-10-2014 05:10 AM
MTPockets1 wrote:
I towed my 5vr the first year with SRW. Pin weight was 3400 lbs. With added weight of in bed tool box, hitch, people, I was 600 lbs over my door label limit. The truck towed just fine, stopped fine, but I was over and chose to get the DRW which I am more comfortable with. Fact is, the SRW was overloaded, DRW is not. If your SRW is overloaded it's not enough truck for the payload. Will you get away with it? Probably, but doesn't change the fact. It's physics. Over is over. Over
Feb-10-2014 04:53 AM
bad99ram wrote:
I would think that since a transporter is commercial they have to stop at weigh stations. If they were not within limits they would be in trouble.
Feb-10-2014 04:42 AM
Feb-10-2014 03:54 AM
