trailair pinbox
12th_Man_Fan
I have a new 5th that came with a Trailair pinbox. I have about 3800 lbs. of pin weight.
Can anyone tell me how much air pressure i should have in the air bag?
i have only pulled it twice with 70psi and it seems a little harsher than I would expect.
I can see if you don't have enough air it will bottom out.
Any experience is appreciated.
2014 GMC Duramax 4X4 DRW Crew
2015 DRV Tradition
15 REPLIES 15
Garry_Gayle
If you need to add air everytime out you need to do a leak test, just add soapy water. I run 80psi on a 3800 pin weight
rjsurfer
I'm on the low end of the scale with my Trail Air, I'm running about 50psi.
But my 5th wheel is only 9,000lbs and pin weight less than grand.
You really have to experiment with the pressure for your rig, don't be afraid to try a lower setting if your still riding harsh.
Ron W.
03 Dodge 2500 SRW,SB,EC
2018 Keystone 25RES
DRZ-400SM
DL-650
campinghut
I run mine at 100PSI and it just barely gets to the top of the arrow.
Tim And Bev
2018 Mobile Suites 38RSSA, 560w solar, 2800w inverter (3 previous Artic fox trailers, 1 Cedar Creek, 1 Heartland Cyclone. In the last 8 Years)
2022 F350 (Previous trucks 2006, 2008, 2012, 2015, 2017, 2019, 2020 all Ford F350's)
Bionic_Man
They do seem to take a lot of air. I need over 80 PSI on my relatively light (11,200 pound) 5er.
I also need to fill it each time out. Why would going to 100 PSI and leaving it filled overnight solve the leak??
2012 RAM 3500 Laramie Longhorn DRW CC 4x4 Max Tow, Cummins HO, 60 gallon RDS aux fuel tank, Reese 18k Elite hitch
2003 Dodge Ram 3500 QC SB 4x4 Cummins HO NV5600 with Smarty JR, Jacobs EB (sold)
2002 Gulf Stream Sea Hawk 29FRB with Honda EV6010
christopherglen
not hooked up the arrow is 7/8 inch below the outer shock housing on mine. I prefer to run it 1/2 to 3/4 inch lower, it rides much better.
2007 Chevrolet 3500 CC/LB Duramax/Dually 4X4 Mine r4tech, Reese Signature Series 18k +slider, duratrac, Titan 62 gallon, diamond eye, Cheetah 64
2011 Keystone Fusion 405 TrailAir & Triglide, Centerpoint, gen-turi, 3 PVX-840T, XANTREX FREEDOM SW3012, G614
12th_Man_Fan
brirene wrote:
Mine also says inflate to the top of the arrows on the decal. Top of the arrow is 4 7/8" measuring from the center of the lower bolt.
Thanks, this will help. someone pulled the sticker off of mine and I didn't get a manual with it. The dealer put a piece of tape on it and I just wanted to make sure it was accurate.
2015 DRV Tradition
Cummins12V98
Boxer Lovers wrote:
Just use the arrow decal posted on the shock. Mine loses air so I check it every time we pull out. Takes a pretty good compressor to bring it up to 75-80 p.s.i. which mine needs to level.
Inflate to 100 psi let it sit overnight and your leak may go away.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
brirene
Jayco Designer 30 RKS Medallion pkg, Trail Air pin
'05 F350 6.0 PSD CC 4x4 DRW LB B&W Companion, Edge Insight
โ€œCertainly, travel is more than the seeing of sights; it is a change that goes on, deep and permanent, in the ideas of living." Miriam Beard
Randu
Air pressure depends on the exact Trailair pin box and the way you load your trailer. I have 2 and the air bag size and volume of air is different. My pin weight is 3800#.
Hitch up and air to the top of arrows is exactly what the manual instructs. Arrowheads are the reference as there is not a standard pressure.
I have a model L05 that is the long pin box and it has a big air bag so it only took 75psi to get to the top of the arrowheads. I now have that box stored in the garage waiting to sell and am using a M15 model of the same pin box which is 12" shorter in length and considered the medium version.
It has a small bag when compared to the long version and takes 100psi to get to the top of the arrowheads.
I checked and recorded psi after 1st set up and test drive. Its easier to check pressure and air up before the trailer is hitched up. That makes the pressures I stated as "Unhitched" pressures.
Randu
2017 Chevy 3500HD SRW Crew LTZ
4x4,Duramax, Allison.
2017 Jayco North Point 381DLQS
Previous: 2000 Travel Supreme
2005 Newmar Kountry Star
2008 Mobile Suites 36TK3
Veebyes
I also had a Trail Air with a heavy trailer. PSI to get to the marked line was very high. Over 100#. Did some checking & they sent me another airbag. Larger. Needed only 60-70# to be on the line.
Much better.
FYI, I currently have a very similar trailer with 5th Airbourne pinbox. Miserable with the thing. Has only half the travel of the Trail Air. Only marginally better than no airbag system at all.
Boat: 32' 1996 Albin 32+2, single Cummins 315hp
40+ night per year overnighter
2007 Alpenlite 34RLR
2006 Chevy 3500 LT, CC,LB 6.6L Diesel
Ham Radio: VP9KL, IRLP node 7995
igor2brvn
My pin weight is about the same as yours. It takes 100 - 105 psi to get to the top of the arrow decal, and this provides the best ride for my rig.
From the peak of good living
Eager to be RVing
2011 Cedar Creek Custom 36RE
2008 Ford F-350 CC Lariat DRW 6.4L Diesel
"Ford makes it, International shakes it!"
Boxer_Lovers
Dave, Robin, and Buster the Boxer
2008 Beaver Contessa, 42, Caterpillar 425
Toad 2017 Ram 1500, Quad Cab, Limited, M&G brake, Blue Ox.
filrupmark
I have a Trailair Tri-glide . I let the air out of the air bag and marked the driver side with a white line with the jaw all the down then all the way up and the I made a mark in the middle of the stroke . When the trailer is connected to our truck I air it up to the middle line which is the middle stroke. With the three lines I can just glance at it and see if the air is adjusted correctly . Works great for us.
2004 Ford F250 Super Duty 6.0 Diesel, Bilstein 4600 Shocks, 16K B&W Patriot, Michelin M&S
2014 Augusta Flex AF34RS Trailair Tri Glide pinbox,
JT Strong Arms , Bridgestone R250'S, KYB Monotube Gas shocks
Finally a smooth ride !!!
RustyJC
Does yours have the arrows on the shock absorber indicating the fill level? With the static pin weight of the 5th wheel on the hitch, you should inflate the airbag until the shock shield is at the top of the arrows. You can vary this a bit depending on your ride preference - obviously, more air pressure will make the airbag more "solid", while lower air pressure will allow it to ride softer, but you don't want it bottoming out under severe bumps you may encounter.
For our Mobile Suites, we run about 85 PSIG in the TrailAir tri-glide pinbox. The pressure yours requires will be a direct function of the pin weight of your 5th wheel. IIRC, the airbag is rated for 100 PSIG maximum inflation pressure.
Rusty
2014.5 DRV Mobile Suites 38RSSA #6972
2016 Ram 3500 Dually Longhorn Crew Cab Long Bed, 4x4, 385/900 Cummins, Aisin AS69RC, 4.10, 39K+ GCWR, 30K+ trailer tow rating, 14K GVWR
B&W RVK3600
