โMay-09-2013 01:10 PM
โMay-11-2013 04:44 AM
blue trawler wrote:
Don't forget when u fill your tank ur valve is facing down then when u finish putting in the water u want to turn the valve side ways and u are ready to go! Trust me on this one. I am a Durango owner and love my Rv!
I always carry about 10 gallons just for that purpose , using the rest room!
Bruce.
โMay-11-2013 04:35 AM
silvercorvette wrote:
I tried to send you a private message but you have all messages blocked unless they are on your buddy list
โMay-11-2013 04:34 AM
Camper Mama Bear wrote:
keep in mind that once you use the toilet on the road you now have what went into the toilet sitting in your black tank. if you are heading home you need a plan so it doesn't cause an odor problem sitting in the tank until you empty it out. some options...1 - can you dump at home? 2 - are you going out again in a few weeks or a month, if so consider putting a deodorizer in the tank (found in the RV section of walmart or any RV supply store). cooler weather you may not need to put the deodorizer in.
I personally am a strong believer in using my toilet whenever possible. so there are very few trips home when the toilet in the trailer is off limits. and for the next year or so with a little girl potty training those times will be even less because if I can avoid bringing her into a public restroom, I will.
โMay-11-2013 04:28 AM
silvercorvette wrote:bpounds wrote:
I would recommend getting off the road before using the toilet.
I wanted to give the OP a chance to get aquatinted before having a little fun, but since you broke the ice I'll jump in with this. I would be worried about about running me over while I sat in the middle of the road.
โMay-11-2013 04:20 AM
ford truck guy wrote:
On my KZ I have 1 inlet for water with a throw valve below... With the valve facing 1 way he water is in the system... With the valve facing the other direction it will fill the water tank....Check to se if yo have an inlet for city water and an inlet for black water flush...THey should be the only 2 inlets you have... If you turn the valve the other way ,you should hear water running just a little bit ..that's good as it is filling up your tank...Joe
โMay-10-2013 08:04 PM
โMay-10-2013 07:28 PM
โMay-10-2013 04:22 PM
silvercorvette wrote:Cruise and auto-pilot are not the same thing:Bbpounds wrote:
โMay-10-2013 03:53 PM
โMay-10-2013 01:53 PM
โMay-10-2013 11:08 AM
โMay-09-2013 10:23 PM
โMay-09-2013 07:54 PM
โMay-09-2013 07:51 PM
