vents in floors
bobbyterri
anyone have any issues with the heater vents being on the floor, particularly in a high traffic area? we are looking at a cedar creek where the vents are right where we will walk on them a thousand times, vs. a solitude where they are not in the floor at all. i know in a stick house it matters...they get crushed.
21 REPLIES 21
Atom_Ant
I always change them out with the louvered type which are a little stronger.
I wouldn't want one in the main traffic pattern, but it wouldn't be a deal breaker for me. Once you're in it for a while, you forget where they are anyway.
2008 Ford F350 2014 Redwood 36RL - Our Rig
Onan 5500, Splendide Ariston W/D, 8K axles, disk brakes, G614s, tri-glide pin box,
6-pt leveling, dual heat pump, dual awnings, Trav'ler SK-1000 Dish
the_bear_II
We have one right in front of the stove in the kitchen area. We keep a small rug over it. The rug has no backing material, it's not affected by the heat when we run the heater. The rug is there to keep pieces of food from falling in the vent as we cook. I'm a sloppy cook....
cKarlGo
The only issue I have ever had with them was on my last unit. The carpet pulled out from under the edge of one and I just could not get it to stay afterwards. Keystone via Camping World resolved the issue without complaint or recurrence.
k.
2014 Itasca Suncruiser 38Q
2014 Honda CR-V
2007 Black Lab/Pitt Bull mix named Harley
downtheroad
We have two in the middle..Allows us to fully use our rig including the furnace with both slides in.
They are not a problem at all. I occasionally pull the registers and vacuum inside.
"If we couldn't laugh we would all go insane."
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
Dandy_Dan
We changed out a couple of our register covers for ones with shut off louvers but no problems. The vents being in the floor also will help in the colder weather keep the tanks from freezing. Good Luck and Happy Camping.
dan218b@tds.net
Dan and Lori Branson
Anna 1 and Lily( The new one)
Sarah-7/16 and Beau at the Rainbow bridge
2015 Ford SD350 Crew Cab Power Stroke
2009 Open Range 337RLS
Old Fella Rally Member
RV.Net Ohio Rally Member
Ram4Sam
My trailer has one in the traffic pattern, two things I don't like about it.....They can be rough on bare feet and if you want to put down any small rugs, you have to move them when you run the heater.
Sam
2016 Dodge cummins 3500 SRW LB CC 4X4 Aisin, Nav, white w/brown
No keys, B&W TOB & Companion
Gone....served me well...1991 Dodge Cummins...2001.5 Dodge Cummins
2008 Thor Jazz 2870UK 5er
Driving a Dodge Cummins since 1991...
azdryheat
No issues with ours.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2019 RZR 1000XP TRE
