โJul-16-2014 07:47 PM
โAug-17-2014 03:04 PM
Bamaman1 wrote:
I just picked up a set of R250's to replace the Chinese Will Pops on my new fifth wheel trailer. They were $195 @ Costco with $70 Bridgestone rebate.
I cannot get over how heavy these ribbed tires are. They're 1" thick rubber, and solid steel cores bead to bead. And they're well over 50 lbs. each.
R250's are tires you see on F450 trucks with utility bodies and cranes--service trucks. They're too beefy to use on a common every day 3/4 ton truck.
The guy at Costco says he's seen'em get 100K miles, and they've had absolutely no problems with the tires. I'm sold on them for RV use--especially at the price.
โAug-17-2014 01:24 PM
โAug-13-2014 03:45 PM
AH64ID wrote:Me Again wrote:
Half the people that post here about good results with Marathons do not even own a 5th! Maybe they are just 5th wheel want to bees! Chris
As stated for the same GVWR the 5er will have lower axle weights than a TT... not sure how that is harder on a set of tires???
Anything useful to add other than banter?
โAug-13-2014 01:55 PM
โAug-13-2014 09:08 AM
Me Again wrote:ah64id wrote:
When used in their parameters they work, when taken outside of them they don't.
True ST tires were designed as a cheap solution for local service on utility type trailers and were not intended for freeway speeds for extended periods. With little changes they now are standard fair on RV trailers.
Which tire would I trust to do the 1650 mile trip from NW Washinton to the East Valley in 3.5 days.
A. 35 Pound poly carcass Marathon
B. 59 Pound steel carcass R250
Which of the above would have one constantly watching their mirrors.
Chris
โAug-13-2014 08:40 AM
โAug-13-2014 08:01 AM
ah64id wrote:
Some issues are valid, some are mute and poor manufacturer design.
Heavier isn't an issue if the proper components are used.
The tight scrubbing is an argument for ST over LT...
Proper parts for the job. Anything at 98% of it's rating is more susceptible to failure than the same component at 80%.
Manufacturers are putting the owners in a tight spot, proper components would go a long ways.
Very few people check tire pressures, nor do they obey speed ratings. Both of which induce premature failure, as you know. Most those people will claim they don't exceed ratings and they check their tires, but that's more of today's blame game than reality.
โAug-13-2014 07:50 AM
โAug-13-2014 06:37 AM
โAug-13-2014 06:21 AM
โAug-12-2014 09:46 PM
โAug-12-2014 03:12 PM
ah64id wrote:ol Bombero-JC wrote:
GY made that one disappear - although it still can be found out there in cyberspace.
When was that? I have a press release form January of this year.
โAug-12-2014 06:02 AM
Michelin publishes a guide of tire pressures based on tire load. (This is linked somewhere else in this thread.) At the loading I will be placing on these tires, I will likely run 50-55 PSI.
โAug-12-2014 05:04 AM
