water heater ??
kemer
On my 2002 Montana 2955RL, the panel for the switches to operate the water heater and water pump has a little light in between the switches. Once in awhile, the light comes on. Just wondering what the significance of that is. I rarely use the water pump so am assuming it has to do with the water heater. Anything to be concerned about? THANKS.........
2 REPLIES 2
brirene
On mine it indicates the the propane burner on the water heater has attempted to light 3 times without success. It won't attempt again until the switch is reset.
Jayco Designer 30 RKS Medallion pkg, Trail Air pin
'05 F350 6.0 PSD CC 4x4 DRW LB B&W Companion, Edge Insight
โ€œCertainly, travel is more than the seeing of sights; it is a change that goes on, deep and permanent, in the ideas of living." Miriam Beard
Carl_n_Susan
Nomad II
Nomad II
That little LED light comes on while the propane water heater is trying to light. It goes out as soon as the burner is ignited. If it stays on it indicates the burner failed to light.
Temp Signature1
Second Line
Third line
Fourth Line
