Jun-03-2022 09:43 AM
Jun-04-2022 05:13 PM
cummins2014 wrote:
Thanks.No idea how it’s plumbed up in there , without pulling the belly off . I have a feeling on my sons it’s what you say , runs a lot of water out of there when it’s full , will have to address it. It reads full at first , but after it quits out of the overflow, as said it’s 2/3. With a 56 gal. tank , he’s losing approximately close to 20 gals .
Jun-04-2022 04:23 PM
Jun-04-2022 04:12 PM
JRscooby wrote:
Extending the overflow up will not change much. I would check the overflow does not extend down inside the tank. If it does, and you fill until it comes out the overflow it will run out down to the end of tube, no matter how high it must go. If that is the issue, and can't fix inside tank. Tee into the top of overflow line, extend up a few inches, then daylight. This will break the syphon, keep tank full.
Jun-04-2022 06:35 AM
Jun-04-2022 04:14 AM
Jun-03-2022 11:41 AM
MFL wrote:
I don't know from experience, but what jdc1 suggests makes sense to me. I would not plug overflow lines, I'm sure you know, that's not best option.
I often fill my tank full, and need every bit of it, but mine is the simple gravity fill tank.
Jerry
Jun-03-2022 11:29 AM
jdc1 wrote:
Extend the overflow hose a few inches above the fresh water tank. That's how it should have been from the factory.
Jun-03-2022 11:19 AM
Jun-03-2022 11:05 AM
