Weekend Warrior Onan 5500 install help
mjmbrown
Hey guys. im having issues with my keyboard so sorry or the typos.
i have a WW s2600. it was missing the Onan 5500. so i stumbled across one on CL or $1500.....40 hrs...deal o the century.
now...what and where do i start with wiring it up. im not sure what i am missing, can anyone take pics o there gen compartment and cord/inverter compartments. so i can get a good visual on what i am missing. gen is complete. has 6' o wire (pos/neg) How do i hook these to dual batteries?
and 6' o wires (2 lack, 2 white, 1 green) where do these go? is there supposed to e another outlet in my compartment to plug the shore cord into? i am confused since every manufacturer is different.
TV- 2005 Chevrolet Silverado 2500HD 6.0L, 6" Lift 35" Nitto Trail Grapplers, AirRaid JR, Magnaflow, Hellwig Airbags, DVD Headrests
TH- 2006 Weekend Warrior FS2600 Billet Edition
2 REPLIES 2
BigDogF250
The short version:
- Connect the two wires for the starter to a 12V source.
- The other wires feed an outlet in the compartment your shore power cord is in, the shore power cord plugs into that outlet to use the generator.
On my 2005 WW which has an Onan Marquis 5500 Gold this is a 120v 50amp outlet which my shore power plugs into. The power feed from the generator is two 30a 120v circuits.
If this is the first time you have worked with 12v and 120v power feel free to consult an electrician, even if it's at the very end. Melting any parts will cost more to fix than the electrician.
If you have a multimeter you can test everything yourself. If you don't have one go buy one, the inexpensive ones will do everything you need.
Congrats on finding the genny!
Don't take life too seriously, it's not permanent.
06 Weekend Warrior FSC3200, Axles flipped, Bridgestone Duravis Tires
2005 Ford F250 PSD 4x4
07 Yamaha YZF450 White/Silver, 94 Husqvarna WXC610
2008 Polaris RZR 800, 2011 Honda CBR1000RR & one Goffin Cockatoo
htr1
http://www.cumminsonan.com/www/pdf/manuals/900-0196.pdf
Maybe this could help your installation
