wet bolt shackles
ford_coupe
I'm thinking of replaceing shackles on our '08 Durango,how do you decide which ones to buy? also what about the shocks? thank you for any help. btw I have 6000# axles.
5 REPLIES 5
Charlie_D_
Get your shocks from a parts house. Brought the old ones in and they had a cross reference for a Monroe. You could also order on line and get them cheaper. The OEM Chinese shocks were bad after a few thousand miles. One was frozen and I could not free up, the other three had no resistance.
Enjoying Your Freedom?
Thank A Veteran
Native Texan
2013 Prime Time Crusader 330MKS
2018 Chevy 2500 D/A Z71 4x4 Offroad
2006 Holiday Rambler Savoy 33SKT-40,000 trouble free miles-retired
2006 Chevy 2500 D/A-retired
2013 Chevy 2500 D/A-retired
hermandutchman
I got mine from a place that sells horse trailers. I bought the complete kit that he happened to have on hand. You can buy just the parts that you need. It can be diy project but does take some time and some mech. ability.
Peg_Leg
I installed the never fail bushings last summer. I've not looked at them this year due to a couple of Carpel Tunnel surgery's. The 5er has sat since April and I've got a bad itch to be traveling.
2012 Chevy 3500HD Dually 4X4
Crew Cab long bed 6.0 gasser 4.10
2019 Open Range OF337RLS
Yamaha EF3000iSE
retired gadgetman
craig7h
Nomad II
Nomad II
You can call lippert and get the correct ones. First go to there web page its full of information on those. Second you can try mobile outfitters, they are a different arm of lippert.
I just finished ording the wet bolts from lippert and called mobil outfitters for tech. help. If its just wet bolts and shackles you may want to try the never fail bushings. Call and talk to "sonny" at mobil outfitters.
Itasca Meridian SE 36g
Road Master Tow Dolly
donn0128
Lippert will sell you the parts direct. When i bought mine i got them directly from trailair pretty reasonable. But they are now part of Lippert, so.....
